LED shows that unit is brewing, however, when pod is inserted, unit merely drips coffee into cup; when pod is removed, unit flows freely. My Keurig with the K-cup in place begins to brew - only drips into the cup, stops brewing, if I remove the K-cup it completes it run of hot water (about 1/2 the amount). I can use the reusable filter just fine, but put a K-cup into the machine and problems. I notice that there are coffee grounds all over the top of the k-cup when it does this funky brewing - is it back flowing? I can run a cup of hot water, use the reusable filter - but no k-cups - any one have a suggestion?
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
reusable cup spits water and grinds tointo cup
when you make a cup of coffee the water will not stop flowing.
