Thanks for sharing the information regarding other product. But, during the scanning method unable to detect the memory card and complete the process. To address such issues, use Remo Recover software to recover deleted or lost photos from memory card.
Perhaps you did hide the pictures. When you hide the pictures, (the ones you don't want to show to costumers) you only get to see them on the computer. To unhide, goto the playback menu look for the line hide pictures and press. Rest must be simple.
SOURCE: Memory card cannot be read
Well this could come from one of 2 problems that spring to mind...
1. You do not have the correct software installed on your PC, as thus presents a problem in reading said memory card, especially if you are using non-specific or generic software.
Ensure the software you are using is for the Nikon Coolpix S200.
2. The memory card may also be faulty, if you feel this may be the case, i suggest having a dealer or repairer take a look at the card.
Tip: Some photo labs have self service units for most types of digital cameras. Drop in and try establishing if the memory card can be read.
SOURCE: How do I transfer pictures onto the memory card?
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
SOURCE: Memory card data won't show on computer
well im just 12 and all but i herd if you keep you sd memory card in the computer and then shutdown(still with it in the computer) then un plug your pc wait one min plug it back on wait till it loads up the take it out and put it back in it might work hope it helps :)
SOURCE: camera not recognised on computer so unable to transfer photos to
Try reloading drivers software that came with the camera.
SOURCE: Retrieving accidentally deleted digital photos from memory card (user error)
You can retrieve deleted pictures from memory card with steps below
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended asoftech photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
here's the video tutorial which you may find useful
