Nikon D80 Digital Camera with 18-135mm Lens Logo
A
Anonymous Posted on Jan 16, 2014
Win 7 driver nikon d80 - Nikon D80 Digital Camera with 18-135mm Lens
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Sep 03, 2014
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442339
Points
622693
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
How can I turn on my Playback Menu for Nikon D80?
Nikon D80 - Revealing the Hidden Menus - YouTube
? 3:11
https://www.youtube.com/watch?v=IEJ1nuPCl_c
May 7, 2008 - Uploaded by LarkPhoto
By default the D80 hides several of the more technical menus so that ... you activate either the 'Full' or 'My menu' option from thesetup menu.
Upgrade firmware for Nikon D80
Confirming the firmware version:
  1. Turn on the D80
  2. Press the MENU button and select Firmware Version from the setup menu. The camera's firmware version will be displayed.
  3. Turn off the D80
Basic Upgrade instructions: for detailed instructions, see pdf files below.
  1. Download and expand the firmware files
  2. Format an approved SD (Secure Digital) memory card in the camera
  3. Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
  4. Copy to the top level of the card the downloaded "A firmware" file
  5. Disconnect camera from computer
  6. Update the firmware from the "Setup" menu
  7. Follow the camera's on-screen menus
  8. Repeat steps 2 through 7 using the "B Firmware"
  9. Re-format Card
D80 1 11 firmware upgrade Nikon Knowledgebase
1helpful
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Need a Nikon D80 Service Manual
http://www.pdfoo.com/result-nikon-d80-repair-manual.html is one website. Doing a Google or Bing I found numerous sites that have these. Maybe contacting Nikon direct will be a better choice for you: 1-800-645-6689
1helpful
How do I get Photoshop 7 to recognise Nikon Raw files. (Windows XP pro. Nikon D80 slr)
I did it by installing (then removing, because I do not use it) Nikon Picture Project. NPP puts the required plug-in into Photoshop 7, and leaves it there
Ron Marshall
Nikon d80 does it records
if you mean take videos.. the nikon D80 does not support the video function..it is a picture only camera.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
