1992 Buick LeSabre Logo
Posted on May 29, 2009
1992 Buick LeSabre armrest won't open.
I recently acquired a 1992 Buick LeSabre. The front seat armrest apparently contains a storage compartment, but I have been unable to open it. What's the trick?
Dale Blanshan
Rochester, MN
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Jun 08, 2009
Anonymous
Contributor
Level 1:
Answers
31
Questions
Helped
15267
Points
83
I have that car, i don't have any issue.. maybe they glued it to trick you?
  • gary
    gary Mar 04, 2014
    yes think they did
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 08, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
4051
Points
6
I have this car. Mine was stuck too. I pulled and pulled until it came open, then bent the mechanism that holds it shut so it wouldn't stick again. It comes open easily now, but it'll never latch again. Basically broke it to fix it.
3answers
Where are the fuses to locate fuse for driver door panel on a 2002 buick lesabre?
PWR WDO - 30amp circuit breaker , DRV -MDL 10amp fuse - both are located in the rear fuse box .
Fuse Block Rear
Under the left side of the rear passenger compartment seat
How do I remove armrest storage between front seats?
Unbolt it there are about 15 bolts that r torx style
Remove center armrest from 2003 GMC
These are usually a combination of Velcro, screws and snap latches. The screws have concealment caps that can be removed with a small screwdriver. The other place is under the rubber liner mats for the "catch all" area and in the bottom of the storage compartment itself. If you have any lighters, ashtrays or power points you will have to remove those first as well. Small screws usually hold those in.
Wher is the electronic control module located on a 1994 buick lesabre
Hi there;
On 1994 Buick Lesabre 3.8L SFI OHV 6cyl the Engine Control Computer is located front seating area, passenger side, behind dash, mounted behind glove compartment cavity.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
How to remove rear seat in a 2005 buick lasaber ????????????
I think the seat design is the same as the 1992 LeSabre. If so this is easy. Grip the seat under the bottom front edge next to the carpet and lift straight up. The seat is held in place by a spring receiver so at this point the entire bottom cushion should now be loose and you can lift it out of the car.
To replace it put it in position and press down until you feel it drop in place. Don't bury the seat belts.
1998 LeSabre center storage console doesn't open
Place the palm of your hand on the top and curl your fingers under the lip and press upward toward your palm,it should then open.When open you can fold the cup holder inside the console.
1992 - 1999 lesabre drivers front door
The LeSabre had the same body style up until 1999 in the rounded style. So it should fit just fine.
Door doesn't open
Sounds like the latch is stuck in the lock position. You will need to remove the door panel to access the latch. This can be difficult with the door closed. You might have to remove the front seat.
1helpful
Fuse numbers
Do you an Owner's Manual to look at. There are two fuse boxes on the 2000 Buick LeSabre. One is under the hood an the passenger-side at the front and the other is under the back seat. The Owners manual has fuse diagrams on pages 6-62 and 6-63 for the engine compartment box and pages 6-66 and 6-67 for the under seat box. Pictures and instructions are also included starting page 6-61.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
