I have reinstalled flash player, updated new version of java and still having problems.I have a black screen then about a minute later the video plays then stops. About 5 minutes later it begins again but for a very short time. It does this throughout the whole video. A 5 minute video takes roughly 1 hour to complete the viewing.
Uninstall both the flash player and the browser, then reinstall, first the browser, then the flash player. If you are using Internet Explorer, I'd suggest you to use another browser. A good one is the Mozilla Firefox (http://getfirefox.com). If the problem persists, it might be another process using too much CPU power, hit "Ctrl+Shif+Esc" and click on the tab "processes" and sort which program is using more memory/cpu, after locating it, hit the button "end process", or "Delete" on your keyboard, then click "Yes" (if it's an unimportant process, only do it if you are absolutely sure if the process is not important for your work/task at hand). If the problem persists, I'd suggest you to backup and format, but only as a last resort. Then restore the backup and install the player again and see what happens.
SOURCE: sony vaio laptop PCG-5J2L montior is black can
Check on line for a bulb to replace the dead one. Cost about 9.00 plus shipping. If you are careful you can do it yourself.
SOURCE: Looking for the specification of the Sony Vaio PCG-8K2R
http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCGTR3AP&upd_id=1087&os_id=7
just click and download your driver
SOURCE: I need a video card
hi tom4ward
Video card in a notebook is integrated you cannot change it.
Try to update your video card driver if it boots you to O.S
Check also your memory. try it on a different notebook if its working, if its not then its your memory is defective if not,
the motherboard or video card is the issue.
Hopefully it helps,
Thanks
Banaple
Testimonial: "Thank you."
