Changing the drum unit
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Minolta EP1085 copier - replaced drum but need to
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
SOURCE: konica minolta bizhub 350 error code c5352
Cooling Fan fault. To clear open and closer the front door.
SOURCE: How to fix Error Code C3901 on a Minolta Bizhub
Enter service mode & Clear All
Utility>Stop>0>0>Stop>0>1
All of this within 3 secs.
Please Rate me.
SOURCE: On my bizhub 250 copier,
This is a service technician performed function. The PC Drum unit is changed by removing the whole imaging unit and then removing the drum section and changing it out. At the same time the developer needs to be cleaned from the developing unit and replaced with fresh developer. The drum counter is then reset using the service mode and then the new developer must be calibrated using the F8 mode. So in this machine's case, this is just not a pull out the old unit and plug in a new one.
If you find the "right" service guy, he can come in and reset the drum counter and do the f8 without changing either the drum or the developer. This can sometimes get twice the life out of the unit. Copy quality can degrade a bit towards the end of the second cycle.
If you just reset it your looking at around $100. If you do everything that is called for then the cost is more like $350.
Good Luck and Thank You for using Fixya.
WheatlandServices
