Apple MacBook PC Notebook Logo
A
Anonymous Posted on Jan 15, 2014
Ejecting a DVD on an external iMac drive - Apple MacBook PC Notebook
aggarrett
Level 1:
  • Contributor 20 Answers
  • Posted on Dec 16, 2014
aggarrett
Contributor
Level 1:
Answers
20
Questions
Helped
6900
Points
24
Alternatively, go to /Applications/Utilities/Terminal.app & type the following :
diskutil eject /dev/*
Phillip Ramirez
Level 1:
  • Contributor 24 Answers
Phillip Ramirez
Contributor
Level 1:
Answers
24
Questions
0
Helped
6322
Points
90
Might be a simple fix... have you tried holding down the mouse when you startup your computer? That is the "Eject Disc on Startup" function.
If so and it didn't work, let me know.
1helpful
Dvd wont stay in ,keeps ejecting
Basically the read-write head is out of alignment. These drift out with use. Unfortunetly they are not economical to repair these days and just need to be replaced.
Usually you find a commercial dvd might work for a while but eventually that on't but a cd will. If you have any commercial cd's pop one inand see. The dvd requires much more accuracy but the cd is quite coarse so it works longer. Eventually it too will stop working.
At this point you have two choices, get the dvd drive replaced with a apple configurred drive or just use a external dvd or even blueray external usb drive. Those will be much cheaper and won't require any downtime or tech fees.
I HAVE AN IMAC 20".
You also could try
Opening up the terminal application found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Tilt your imac so that the DVD drive is pointing downwards and press the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the imac switched off insert the piece of plastic with the tape facing down in relation to the screen. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
My imac dvd drive reads DVDs but ejects CDs and installation disc
The optical drive has separate hardware for reading CD-disks and for reading DVD-disks.
So, "half" of the drive has failed. Replace the drive, since that will be less-expensive than an attempt at a repair.
2helpful
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
1helpful
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
My 20 inch imac wont stop trying to eject stuck dvd
not if you don't want to ruin the warranty.
maybe a certified repair shop can replace the drive for you.
2answers
IMAC G5 DVD-ROM slot keeps ejecting disks
Try cleaning the lens or the drive with a cleaning disk
Imac g5 ejecting dvd/cd media
most likely, your dvd burner lens is burnt out(they make the darn things out of plastic!). Just happened on mine. you have to either replace the drive or get an external. There are do it yourself instructions on Apple's website for replacing the drive.
Not all drives are compatible...must be slot loading and I read that it has to be set to master so you can potentially boot from CD's in this drive.
2answers
Accidental ejection
try turning the external drive off & wait a minute then turn it back on.if it works just drag what you want to transfer from your mac to the external drive and it should copy it to the drive.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
