SOURCE: I have hung my projector
Hi...Do you have the manual?
That will list how to do the upside down image
SOURCE: I just replace a lamp
You should turn on the VP-CS20 with the button on projector, NOT THE REMOTE or the instructions wont work. Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT" and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode. Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups to the customer setup menu. Press the "MENU" button to view. Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press "RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to zero in the service menu. Hope it helps, FVazquez
Hope it helps,
FVazquez
