Heres how to restore your MPD24 factory defaults using the Vyzex software:
1. Plug in your MPD24 with USB cable, and then open the Vyzex software.
2. Click File > Open
3. Select Factory SET.SQS, and click open it.
4. You should now see BFD Lite and other details on the Vyzex MPD image.
5. As long as you're on the DATA tab, you should see a PUT SET button available. Press it to transfer the factory presets to your MPD24.
6. An overwrite warning will be displayed. Press YES to overwrite your damaged MPD24 presets with the factory presets.
You'll see a progress bar filling up for about 10 seconds, and then once it disappears, that's it!
You're all done - Enjoy!
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
