Question about Emerson SmartSet CKS1850 Clock Radio
Wrong date on the radio.
How do I change the date.  The back up battery went dead and during a power outage the radio shut down entirely.  When I replaced the battery and plugged it in the date came up as Jan.1st 08.  It is ony Oct. 0 and the days of the week are off..  How do I change the date to the current date as this effects the setting of the alarm days of the week?
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Posted on Dec 22, 2007
My smart clock is 10 nminutes behind, Do I need a new battery, or can I adjust the clock?
Posted on Jan 10, 2009
I followed the reset to the tee and this did work. To get the correct day, month and date I need to set the year to 2006. ??????????????????????????????????
ANy solution?
Posted on May 02, 2008
SOURCE:
How do I get the battery to operate the clock when the power is off. I have the battery in correctly, but when the power is off the clock goes off?
I just read the manual an I am not sure it does. The manual says nothing about that. My clock does the same when power fails. Comes back to correct time when power returns. I miss that on my older clock. Display never went out even during power outage. You can call Phillips an ask or email. It is on there site.
Jan 27, 2015 | Philips Aj 3540 Big Display Clock Radio
Cyberpower 425 va When the device kicked in during
You can change that. It is designed to alart you during a power outtage. That way you will have time to shut down your servers. It will alway alarm during a power outage. But check to make sure your batteries are in good condition
Sep 09, 2011 | CyberPower Intelligent LCD CP825LCD 825 VA...
My emerson cks1850 still stuck to the old daylight savings time and I need to fix it as i rely on it for work and frequat power outages we have were i am and the auto reset is why i like it but now it...
unplug the clock radio from the power, take out the back up battery ( if it has one). let it set for 60 seconds or so, plug it back in, It should now be flashing 12:00 over and over. now reset the clock to the correct time and date.
Mar 14, 2011 | Emerson SmartSet CKS1850 Clock Radio
Why is it our computer server keeps on rebooting or ups can't properly function during black out?
Without further information as to the exact symptoms, it is important to point out that UPSs are only meant to function for a short amount of time (between 3 and 30 minutes, depending on model). The UPS will simply run out of battery power after that time. If the UPS has a computer interface, it may instruct the server to shut down when primary power is lost to prevent data destruction.
If the UPS does not function even briefly during a power outage, the batteries have liken gone dead and either they or the entire unit will need to be replaced. Another possibility is that you do not have a UPS at all, but a surge protector or other device that does not supply power at all.
Oct 21, 2010 | Computers & Internet
Can my alarm clock be changed to automatically change for the new day light savings times? I have one clock and I bought one just like mine for my mother.
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 05, 2009 | Emerson Smartset Clock Radio
Time and date change
Go to your Bios Settings. Change the System Date there.
Dec 27, 2008 | Dell Dimension 4600 PC Desktop
Ups troubles
What is happening here is you are transferring load to battery during a power outage but on return of Line Power the UPS is not smoothly transferring back to Normal mode. As a result you are basically turning off your computer. Two options... shut down your computer orderly during an outage or buy a new UPS.
DD
Dynamic Power Solutions LLC
Aug 20, 2008 | Computers & Internet
IBook G3 900mhz 14" lcd
The date and time are held by the battery so I would guess the battery is going dead or is. Try keeping it plugged in and shut it down for a few then reboot. If the time and date stay good guess the battery is dead. Also make sure you get the power management firmware update from apple. hope it helps
Apr 18, 2008 | Apple iBook G3 Mac Notebook
958 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
