Vehicle Parts & Accessories Logo
A
Anonymous Posted on Jan 16, 2014
Adjust transmission bands - Ford Vehicle Parts & Accessories
Kardoc
Level 3:
Top Expert:
  • Ford Master 7,503 Answers
  • Posted on Feb 19, 2019
Kardoc
Ford Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2760271
Points
58323
Which transmission? Some bands are not adjustable without getting into the transmission case.
2 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Mar 24, 2009
SOURCE: 2002 Ford Explorer with 5R55W transmission: How
I can't find any reference to an adjustment in the overhaul manual, so i will assume this means no adj ness. or provided for.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 22, 2012
SOURCE: how to adjust reverse band on ford fmx transmission
Just google it, there are lots of sites that come up.
Is there a transmission band adjustment or not on 09 matrix for 4th gear
automatic transmissions have both band and clutch adjustments
take it to an accredited auto transmission special shop for the inspection and adjustment
1helpful
How d I adjustthe band on 92Dodge Caravan
Low reverse band
Loosen, then back off locknut approximately five turns.
Tighten adjusting screw to 41 in.lb.
Back adjusting screw off 3 1/2 turns, then tighten lock nut
Kick down band
The kickdown band adjusting screw is located on the left side, top front of the transaxle case.
Loosen locknut and back off nut approximately five turns,
Ensure adjusting screw turns freely in the trans axle case.
tighten band adjusting screw to 72 in.lb
Back adjusting screw off 2 1/4 turns, then holding screw in position, tighten lock nut
1helpful
Automatic transmission service adjustments for 2000 mazda bravo
There should not need to be any "adjustments" for a normal fluid and filter service for your vehicle, unless you have replaced some parts of your transmission that requires adjustment such as the gearshift lever, intermediate and overdrive band, throttle cable, or transmission range sensor/switch.
With that said, the band adjustment specs are "Tighten the band adjusting screw to 10 Ft.Lbs. (14 N.m.) then back off 2 full turns. While holding band adjusting scew stationary, tighten the locking nut to 35-45 Ft.Lbs. (48-61 N.m.)
2answers
Where is the band adjustment on the transmission for a 1993 lincoln mark viii
Hello! The transmission in your Lincoln is the 4R70W...4R70W does not have band adjustments. it is a 4-speed automatic transmission with overdrive that is computer controlled..Th Manual Lever Position Sensor goes bad due to transmission fluid seeping into the sensor's connector..Send a comment if you require additional information or help..Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
How do I adjust the bands on my 1993 Jeep Grand Cherokee Limited AW-4 transmission?
WHAT TYPE TRANSMISSION YOU WORKING ON AND WHAT BANDS ARE YOU ADJUSTING FRONT AND REAR YOUR TYPE VECHICLE HAS MANY TRANSMISSIONS 42RE , 42RH , 44RE , 46RH , 46RE, NEED TO KNOW WHAT TRANSMISSION BECAUSE EACH TRANSMISSION HAS 72 INCH LBS TO ADJUSTMENT ON BAND ADJUSTMENT SCREW BUT YOU WILL HAVE TO BACK OFF DIFFERENT TURNS ON EACH TRANSMISSION.
1helpful
87 cutlass no reverse
foward and no reverse.In order for the reverse to happen there is a transmission brake assemble,the transmission band holds the brake assembly thus allowing fluid to be driven according to gear selection, when no reverse happens there is a malfunction of mechanical or hydraulic part, Depending on the condition you can adjust the kick down or adjust the band. A general procedure for automatic transmission band adjustment involves tightening the band adjusting screw to a given torque sequence, back off the adjusting screw from turning while torque-tightening the adjustment screw about a 1/4 turn and lock down the lock nut,and recheck to see if reverse has been restored.
Transmission overhauled, however, band overadjusted
Bands are not adjustable. Why do you think it's a band issue? The band only comes on during manual second gear, not second gear while in drive. It sounds like a check ball was inadvertently left out of the valve body during reassembly.
2helpful
2answers
1998 subaru band adjustment for auto transmission.
It is on the left side hard to spot. Look below the heater hoses. Good luck, take your time and have a great day.
4helpful
2answers
Automatic transmission band adjustment
Don't have specs on band but the rule is that it should be close enough to the drum to engage without slamming, and loose enough to permit drum to turn without band dragging on it. Biggest problem I've seen people have when adjusting is that adjustment tightens down while turning lock nut. To avoid this, I usually adjust a bit looser than final adjustment so it tightens to correct position instead of becoming too tight. Don't drive 'till you have it right or you will burn band surface. When engaged in reverse, band should be applied and cannot drag. If you adjusted another band, check that one for improper adjustment.
1helpful
Jeep grand cherokee revs for to high before changing gear
Message:
My 2002 Dakota has been somewhat confused about shifting as well. It showed a code P1762. I dropped the pan to install a new fluid filter and fluid-(use only ATF+3 or ATF+4). Since the pan was off I decided to adjust the bands. The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
The front band adjusting screw is on the driver's side above the shift linkage. The rear band is inside the fluid pan near the filter.
1. Loosen band adjusting screw locknut. Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw
threads if necessary. The front band adjuster is on the outside of the transmission and the locknut requires a 3/4" wrench.
2. Using Inch Pound Torque Wrench C-3380-A, a 3-in. extension and appropriate Torx� socket (T-40), tighten adjusting screw to 72 in-lb. CAUTION: If Adapter C-3705 (from SPX Miller) is needed to reach the adjusting screw, tighten the screw to only 47-50 in. lbs. torque.
3. Back off adjusting screw the number of turns listed below for your transmission.
4. Hold adjusting screw in place and tighten lock-nut to:
41 N�m (30 ft. lbs.) for the front band
34 N�m (25 ft. lbs.) for the rear band
The adjustment screw inside the case is a square head bolt. You will need a 1/4 square head socket to fit your torque wrench.
Band adjustments for each model year:
1994
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
o 32/42RH - Tighten to 72 in-LB, back off 4 turns
o 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
o 42RH - tighten to 72 in-lb, back off 2-1/4 turns
o 46RH - tighten to 72 in-lb, back off 2-7/8 turns
o 47RH - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE/RH - tighten to 72 in-lb, back off 4 turns
o 46RE/RH - tighten to 72 in-lb, back off 2 turns
o 47RE/RH - tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
o 42RE - tighten to 72 in-lb, back off 3-5/8 turns
o 46RE - tighten to 72 in-lb, back off 2-7/8 turns
o 47RE - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE - tighten to 72 in-lb, back off 4 turns
o 46RE - tighten to 72 in-lb, back off 2 turns
o 47RE - tighten to 72 in-lb, back off 3 turns
1999
* Front Band
o 42RE - tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
o 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
o 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
+ The 47RH rear band requires a 1/4" hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
o 42RE - Tighten band adj. screw to 72 in-lb, back off 3 turns
o 44RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
o 46RE - Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
o 47RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory
specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns.
Depending on the circumstances I have backed off the band up to 2 1/2 turns.
* Rear Band
o 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut - 30 ft-lb
* Rear band adjustment locknut - 25 ft-lb
* Transmission pan bolts - 13 ft-lb
I just replaced the solenoid with the recommended transducer and all is fine now. The transducer cost me about $50 at a nearby dealership.
Hope this helps. -zman. [email protected]
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
