Frigidaire FES367 Electric Kitchen Range Logo
Chris Lindstrom Posted on Jan 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fes367dsa fan runs while baking but it is not a convection oven
Why is the self cleaning fan running while oven is baking
  • Official Brand Answer 4,342 Answers
  • Posted on Jan 17, 2014
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466531
Points
5907
Chris Lindstrom,
I understand that you have a fan running while you are baking. This is a totally normal function of your applliance. A cooling fan may automatically turn on and off to cool internal parts. It is normal, and the fan may continue to run even after oven is turned off.
-Best Regards-
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Jun 19, 2007
SOURCE: Convection fan does not turn off when door opens
fan is operated by a door switch which has jammed. as i recall, this is located inside the rhs side panel
Anonymous
  • 1314 Answers
  • Posted on Sep 09, 2008
SOURCE: Fridgdaire self cleaning latch
try holding in on the door latch plunger the one that turns the oven light off when you close the door then press start then cancel and inspect the door plunger for any damage
Ismael Rodriguez Batista
  • 188 Answers
  • Posted on Dec 10, 2008
SOURCE: Broiling and Baking Element Stopped working
the thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
Anonymous
  • 3361 Answers
  • Posted on Feb 21, 2009
SOURCE: the broiler works but the self-cleaning and baking
Remove the rear panel and ohm the thermal fuse for continuity.
If bad replace it.
P.S. Do not use the self clean feature on ovens. It is detrimental to continued operation.
Anonymous
  • 3 Answers
  • Posted on Jul 18, 2012
SOURCE: Convection fan doesn't turn on
Found this site cuz I had the same problem- as your purchase was 4 years ago- not sure that I'll help you... But help others who are stumped... I pushed the QuickBake button to preheat then to turn the fan on I pressed it again... ( actually a couple times messing with it...) Once it gave me a " double beep" and sometimes just a single beep but none the less, the fan turned ON!!! Good luck!
No heat on convection or self clean
If you have been using the self clean feature, you have probably burned out or damaged the connections to the fan and the convection fan element or thermistor. NEVER EVER use the self clean feature.
https://www.partselect.ca/Models/CGEB27S7CS2/Sections/BODY/?ModelID=1073773&ModelNum=CGEB27S7CS2&mfgModelNum=&ManufactureID=4&Selected=OTRVH5GS&Position=1&mfg=Frigidaire&Type=Wall%20Oven&Mark=1
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or 500 C°) to ...
‎How Self Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Why You should Never Run A Self Clean Oven Cycle & A ...
https://www.generalappliancesvc.com > why-you-shoul...
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) .....
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
When using the lower oven, the fan runs when using the regular bake mode...should it be doing this? I thought the fan only ran when using the convection mode.
I don't know what brand oven you have, but my oven (Wolf) runs the fan every time the temperature is up. Convection runs a second fan.
Mar 31, 2018 • Ovens
1helpful
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
How do I use this oven? Is it working correctly?
It would seem that the oven is small enough that a fan to flow the heat from the unit would be in use for both convection and bake modes. Usually convection ovens will have a "burst" of fan action during the bake process and it is not a steady fanning of the air that would dry out your cookies, ect. I have a small oven / microwave and my larger oven is a GE that has the "burst" convection that I described. Might not be that much help, but it's hard without more info on your unit. sometimes the model is behind the oven door.
2answers
Fridgidaire Wall Oven will not heat
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
