My gateway convertible tablet pc freezes up after being on for a few mintues. I tried changing the HDD, but that didn't resolve the issue. How can I resolve this issue?
SOURCE: i have a gateway laptop pc with windows vista and its mouse freezes
leave it pluged in do windows updayte dl all updates itgets al dl www.ccleaner.com tool get junk out may need new battery also cant hold it on battery when u do windows updates plug it in only
SOURCE: Cannot change the screen orientation on my Gateway M280 tablet PC
Ok so I had the same problem on my tablet cx2000. Did you download any of the service packs from xp? If so that is what is causing the problem. Your computer will work fine without it so you just need to de-install it. Go to your add and remove programs and delete the service pack. Once your computer reboots then it will be fine!
SOURCE: ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
