FREEZER SIDE FREEEZES UP ABOUT EVERY THREE WEEKS. I'VE DONE EVERYTHING, CLEANING COILS, DEFROSTING MANUALLY, EMPTYING OUT FOOD I DON'T KNOW WHAT ELSE TO DO. IT SEEMS LIKE THE COILS IN BACK ARE COATED WITH ICE AND IT TAKES FOREVER TO DEFROST. THE FREEZER ALSO GETS WARM AFTER IT GETS SO COATED WITH ICE
Hi I t seems like the Defrost timer is not working or is stuck. It could also be the defroster coil but probably not. The timer is located in the front of the refer where the toe kick is . remove the toe kick, check for a square or rectangle box with a big plug on the back. that is probably it. Check with the appliance zone online you need the Mod. # for the parts blow up. look for the defrost timer on the print. that will also show where it is located with a part #. you can then price it out . It is not too hard to install be sure to unplug it before removing any wiring.
Good Luck, Bill
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
SOURCE: whirlpool frig has dual solenoid
some whirlpool refrigerator icemaker works with the defrost the best way call service
SOURCE: I had a problem getting the ice bin back into my
Perhaps I was mistaken, but I thought your website was a source of information about my problem. I have received no input. Please delete my request.
SOURCE: The Refrigerator is 2 years old, and is no longer
Hi Chris,
The problem would seem to be that you developed a small leak in the refrigeration system. This is also assuming that you checked and cleaned the condenser coils which are underneath the fridge. Excessive dirt could also cause this, but from what you are describing I would say the problem is more then that and you have a leak...
The only other thing would be thermostat sensor issues, but then the compressor would be cycling and not running steady...
heatman101
SOURCE: freezer too cold, refrigerator warm
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
