LG 24 in. LDF 7811 Built-in Dishwasher Logo
A
Anonymous Posted on Jan 15, 2014
Not enough water in my lg dishwasher - LG 24 in. LDF 7811 Built-in Dishwasher
2answers
Why does it stop running after two mins and has an error code of OE?
The OE or Overflow Error code.
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
1helpful
LG dishwasher, it pumps out ok on start up in any program, but gives an OE error
I have a lg dishwasher and it ran for an hour and a half and then displayed E1 on it. Then, it would not stop running and wouldnt even turn off so i had to turn it off by the breaker. any solutions?
(1) The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
(2) The float switch actuates in order to prevent the dishwasher from overflowing. If the float switch is defective or stuck, it might not stop the dishwasher from overflowing. If the float switch is defective, replace it.
One would need the model number of your machine.
The spray arms aren't spinning, any ideas?
The main water pump sounds to be defective, not supplying enough water pressure to turn the spraybars.
What can cause and lg dishwasher to not fill water and stop and show le code
Please try the plain VINEGAR in the bottom of your dishwasher. It cleans out the pipes. When you start the machine it automatically starts to drain whatever water has been left from previous cycle. When this cannot happen, due to blocked outlet pipe, it will not precede with the wash cycle. Adding the vinegar, leaving it a few hours, or overnight (hey, I left it for a week one of those times!), it is enough to liquify any heavy fats in that pipe...enough to start the cycle and the normal draining gets reinstated.Hope this helps you, it is such a pain to go & choose another dishwasher to fit into the space allowed & that has all the functions you need. This 'fix' cures all my dishwasher blues! Havagreatday!
LG Dishwasher water flow is weak coming out of the lower spray arm. No water coming out of the upper spray arm. I changed the water inlet valve, and there isn't any difference.
There is a possibility the water pressure itself is low from the kitchen line or the dishwasher is set at incorrect water pressure setting and does not collect enough water based on the flow time of inlet valve. If you hear the wash motor cut in then there is not enough water in the base to start pumping it to through the arms.
Water not hot enough
Before you start dishwasher on your sink start the hot water then after you start dishwasher then you can turn sink off. Hopefully this will help.
Water pump presure is low
Obstruction I would say. check connection from supply, hose not folded or whatever.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
