My Tissot PRS 200 Choronograph cannot reset counter hand (the counter stuck especially in the morning). Anybody with any suggestion?
The owners manual mentions how to fix this but the instructions are not 100% clear. You can download the PRS200 manual here:
http://www.tissot.ch/data/usersmanual/134-en.pdf
Each of the 3 chrono hands are reset separately. Unscrew the crown and pull it all the way out (2 stops out). Press button A (top right) as many times as necessary until the hand is on the 30. Each press moves the hand one tick so you may need to press it several times.
Next push in the crown one click.
Press button B (bottom right) as many times as necessary to advance the 60 second hand to 12'oclock.
Press button A to advance the 1/10th hand to 0.
The part I did not get at first is the fact that you need to press the A and B buttons several times to advance each hand 1 tick at a time until they are all pointing to 12'oclock.
Wow thanks worked great!!!! always took it in to get reset this time just looked it up online!!!
Ryan Bondy
Windsor, ON Canada
Thanks for advice. I pull out the one click and then pushed button B and then all good.
Exactly the same thing happened to me this morning with my PRS200
Watch returned from jewellers after battery change. Reset stop watch returning to 3sec before 12oclock position. Also 10th sec doesnot return to zero.
Last Saturday after the buttery change I had my 60 sec pointer off by 1sec. The instructions helped and I fixed it.
Thanks.
Thank you so much - I had exactly the same problem and was going to take it back to the shop. Thanks! Ollie.
thanks !! it helps with my certina DS podium !!
