I tried admin password reset and user reset and it does nothing.
If your voice mail system is a Call Pilot on a BCM phone system. Use Feature 983, enter the Log number 738662, enter the password set for the system. At this point the display should show Admin with options MBOX -- AA -- OTHR select MBOX. Select CHNG and enter the mailbox number which should be the same as your extension number. The display should now show Password with options of RESET and NEXT. Select reset and your password will be reset to 0000. Press the release button and call into your mailbox using the password 0000. The system will have you change your password and verify it. Hopefully this will fix your problem.
SOURCE: NorStar T7316E Corded Phone Problem - mailbox locked
You will need to dial into the system admin of the voicemail
Feature 983
the password is dependant on how many digits your extensions use. 1020000 for 3 digit and 10020000 for 4 digit, 120000 for 2 digit.
go through the screens
Mailboxes, modify, scroll to password and press change.
Will reset to 0000.
SOURCE: Resetting System Administration login password
Hi Carrie,
Sorry I have been installing a system in a remote area and they do not have Internet access as of yet. Here's what you need to reset the System Manager Password,
Feature 9 8 5, display will read " Set : ### ", press " 9 ", enter the following using the dial-pad: 7 3 7 3 8 7 6 7 7 9 3, display will read: " reset password? ", press YES, press RLS. This should fix the logging in problem. Let me know, ....Mike
SOURCE: Nortel T7316E need to reset all the password
How to Change a Mailbox Password
1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
SOURCE: I am locked out of
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
Testimonial: "OMG THANKS SO MUCH!!!!!!!!!!!!!! YOU FIXED IT!!!! THANK YOU THANK YOU!"
