I had instaled two new battries 3 months ago and now i cant go 6blocks and the battries are dead I went back to the supplier he testsd the battries and the charging system and found nothing but im still left with the same problem can you help thank you Jim Garden e-mail [email protected]
The rule which governs these rechargeable batteries is they require being charged FULLY then used down to 50% capacity. Repeat this cycle approx 10 times, and this will assure you of most likely a year +/- use at full capacity. Hope this help you.
You probably need to replace your batteries again most batteries in a owc need to be charged 12 hrs a day for the first month at least to build up the capacity if not they will slowly dwindle and wont last long and will need to be replaced
depends if its a batteie or mains if battrie change when it stop working if its mains any time its light a light bulb and they cant be fixed you have to replace it 4-5 years some times but new cookers dont last long at all 2 years some times ok
check to see if the battrie is full charge most likely the battrie is dead charge it for two or three hours if it dosent start the battrie is probley bad , clean the battrie termnails or if you have jumper cables jump it if it starts let it run for 20 minutes shut it off and try to start it if it dont start most likely the battery is bad
could be a radiator prublem, or fuse box... but, it could just need to bee cleaned internally. buy a bottle of nos octane booster its 13 bucks at any auto zone and you pour it into your gas tank and it blows out all your engine gunk n ****.
you need to have some fuel in the system over night as when it is shipped it is completly dry when this is done it should start with out any problems if it still has the same problem then you will need to charge the battrie
test the battrie its problay needs replaced Hope this helps give me thumbs up if that what it was seya. Ow if you got jump the battrie done for unless you left a light on ore sometthing and it would take more 5 minutes for the altinator to charge the battrie. Interstate make good battires and sears do to but way over priced,
