It could be as simple as a power off/power on. However, if there needs to be an incline adjustment, you have to determine if your model allows such an adjustment by the user. If it does not, you have to seek such service from the company. Here is the company page identifying the error:
Two ways to reset your EPSON printer ink counter, ink cartridge, protection counter and more.
A. SSC Service Utility For EPSON Stylus Printers
This utility allows you to do many amazing things with your EPSON printers:
Work directly with CSIC in EPSON Stylus printers cartridges.
Reset or rewrite any chip using special add on device.
Freeze internal ink counters.
Reset internal ink counters even with empty cartridges.
Separate cleaning of color and black heads for all EPSON ink jet printers, powerful cleaning mode.
Hot swapping of cartridges supported.
Resetting of protection counter (even then it is already full).
More then 100 different EPSON printers supported.
This program helps people with high printing demands to save money (program works with both black and color cartridges). The software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers. Click here for the SSC Service Utility for EPSON Stylus Printers
B. Using the EPSON Ink Pad Reset Utility
"Parts Inside Your Printer Has Reached The End Of Its Service Life"
Generally, this error message is caused by the malfunction of non user-replaceable parts within your printer. If your product is displaying the "End Of Life Service" message, please view and complete the required information from the link below to proceed.
power fault with error 8. motor controller failure . Test for output voltage for to input voltage motor, If there are NOT the controller is faulty, if there are the motor is faulty. SEE the diagram attached. God bless you
You have had a flat battery for a long time hence the cells tend to be dead. Make sure the power adapting is remitting the right voltage with the use of a multimeter set to dc voltage at 20V. Most power adapters are within the range of 13 and 19.5V, so 20V dc should be selected for a correct reading ok. Having comfirmed that to be ok, you should just power off your pc and have it connected to a power outlet for a least 2hours. If there is still no sign of battery life, then it should be changed as it might have exceeded its life span. Most of such batteries have an average life span of 5 years depending on use though. Good luck
