Dell Studio 1537 Laptop Logo
A
Anonymous Posted on Aug 07, 2017
When I turn on my Dell Studio 1537, stays in hibernating
When I turn on my Dell Studio 1537, Resuming Windows message appears, then Hibernating message appears, with the cursor spinning. The battery light is blinking. Just stays in hibernating. I have removed the battery, I have tighten the charger connection and rebooted several times, F8 as the system comes up to try and go into safe mode, did not work. None of these helped. What else can I try?
Minister Ruland
Level 2:
Sergeant:
  • Dell Expert 445 Answers
  • Posted on Sep 17, 2018
Minister Ruland
Dell Expert
Level 2:
Sergeant:
Answers
445
Questions
0
Helped
127437
Points
810
Take the battery out and see if the computer boots up. if it does then you will have to replace the battery. most of the time when the charge lights blinks the battery is bad
3 Related Answers
Anonymous
  • 44 Answers
  • Posted on Dec 08, 2009
SOURCE: i have a dell studio 1537 volume indicator stays on screen
Either what nick said(which I agreed with), or some keyboard key is stuck? o.O
If that don't work, try repairing windows.. (boot with the OS disk and attempt repair)
Anonymous
  • 200 Answers
  • Posted on Jul 24, 2010
SOURCE: dell inspiron 1525 when starting it says resuming
Turn the computer off, remove the battery, make sure it is not plugged in to power, and hold the power button down for 10 seconds. Wait about a minute before re-installing the battery. If it does it again, hold F10 while the computer is turning on, this should bring you to the "boot select" menu, use the arrows on the keyboard and select "start windows normally" instead of "resume windows". When you get it started up run "Defrag" to prevent this from happening again.
When windows hibernates it saves everything in the ram to a "swap file" on the hard disc. Sometimes hard disc's get "bad sectors", this is considered wear and tear, it happens eventually to all drives. It sounds like there is a bad sector on your disc where the swap file is stored, so you have to start windows without using that part of the disc, then by running defrag the computer will find the bad sector and remember not to use it anymore.
Have a nice day.
Anonymous
  • 51 Answers
  • Posted on Jul 13, 2012
SOURCE: dell studio 1537, the volume indicator icon showing on my screen, don't know how to make it dissapear
You have the touch sensitive Button Stuck
Heres a Youtube Video of how to fix it.
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
When I power on my laptop instead of saying resuming windows it says hibernating
If you have the recovery disk of your laptop.First boot cd/dvd rom drive and load the recovery software and follow on the screen instructions. That will restore your computer factory settings but be careful and not to forget to back up or save your data or files before recovering your system.
If you can resume or turn back to windows desktop, try updating your windows or downloading updates from Microsoft to fix some bugs or errors.
Please rate me
2helpful
I have a dell studio 1537 laptop and have had windows 7 installed. Is this laptop completely compatible to the windows 7 os ?
Studio 1537 is one of the classic models from Dell and it definitely compatible with win 7.. This laptop can be used for high end gaming and visual effects.. Its a good one...
7helpful
Dell inspiron 1525 when starting it says resuming windows then goes to hibernating with a little blue curser going around
Have a nice day.
2answers
I have a dell studio 1537 volume indicator stays on screen
Try system restoring it by going to the date that it worked. Just type it in the search box on your start menu and go to it and follow directions.
1helpful
Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
