Radio Communications Logo
Posted on May 28, 2009
Wiring a Silver Eagle six-pin for a Ranger 6900 F150
I just received a Silver Eagle from a friend of mine and I want to wire it up for my Ranger 6900 F150. The mic is currently configured as a six-pin...
  • cruzer_27385 May 31, 2009
    Thank you for that information.
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on May 31, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
7061
Points
19
PIN #1 is common & shield(black&braided) 2 audio(white) 3 tx(red) 4rx(blue) if you knew what it was hooked to before it would be helpful.
I have a 6 wire D104 . How do I wire it to a Ranger 2985 dx ?
Wiring a 6-wire D104 microphone to a Ranger 2985 DX requires connecting the wires in the correct order and configuration.
The Ranger 2985 DX has an 8-pin modular plug, and the D104 microphone has a 6-pin modular plug.
Here's one way to wire the D104 microphone to the Ranger 2985 DX:
  1. Connect the red wire from the D104 to the 8-pin modular plug's pin 4 (PTT - Push-To-Talk).
  2. Connect the black wire from the D104 to the 8-pin modular plug's pin 5 (Ground).
  3. Connect the white wire from the D104 to the 8-pin modular plug's pin 6 (MIC + Audio).
  4. Connect the blue wire from the D104 to the 8-pin modular plug's pin 7 (Receive Audio)
  5. Connect the green wire from the D104 to the 8-pin modular plug pin 8 (Transmit Audio)
  6. Connect the yellow wire from the D104 to the 8-pin modular plug's pin 3 (UP-Down).
It's important to double-check the wiring configuration with the user manual of the Ranger 2985 DX and the D104 microphone. Some manufacturers have different wiring configurations and it's important to match the wiring accordingly to avoid any damage to the device.
It's also worth noting that if you are not comfortable with the wiring process, it's best to consult with a professional technician or a radio expert.
Problem with wire colors in my Silver Eagle Lollypop Mic
The cable to mic / radio base has been replaced and is not stock. The factory diagram is d104-silver-eagle-wiring-diagram-3.jpg (1275×2100) (schematron.org)
If that is the only difference then anywhere the wiring diagram shows blue to the mic connection, use the white wire.
1helpful
Can you help need the wiring for astatic silver eagle mic to wire up to the yeasu ft-757-gx radio
The best info I can find iis
radio mic
pin5 blue mic ground
pin6 red ptt
pin7 screen
pin 8 white mic
Astatic d104 wiring for Yaseu ham radio
( 9 Stand ) Astatic D104 to Yaesu FT 990
Pin 1 is White
Pin 2 is Red
Pin 7 is Shield/Blue combined
What is the wiring for turner mb+5 base mic to superstar v6 version 6900 can any body help please thanks
Turner +3B to Superstar SS6900
Pin 1 is Shield
Pin 2 is white
Pin 3 is Black
Pin 4 DO NOT TOUCH ANY WIRES TO IT.. ITS LIVE VOLTAGE! (mic and radio go poof if you do)
Wiring a Silver eagle to a Ranger 2980
PIN 1 SHIELD AND BLUE,PIN 2 WHITE,PIN 3 RED ,PIN 4 BLACK ,PIN 5 AND 6 NOT USED THEY ARE FOR CHANNEL UP AND DOWN
3answers
How to wire a Golden Eagle Astatic D-104 Mic to a RCA Cb Co-Pilot 14T303 4 pin connector
i have a gold eagle mark 4 i like two put a 776 mike back on it but i do not know the w coed .thank you .
2helpful
I have an astatic 4 pin d104m6b amplified
Hello there
Nice mic i have 3 of these
here is infornation that you can use to get the diagram i like the first link a lot better though it is in full color Ok just look belowtis post and it will be there ok? I hope that this is very helpful for you
Best regards Michael
Repairing the D
These Astatic D-104 microphones are all vintage. ... Doing so will reveal the
simple wiring and the wiring diagram, pasted to the plate on the inside. ... http://www.k3hkr.com/D104_repair.html - 4k - Similar pages I am needing the wiring description for the astatic d104 - FixYa Oct 24, 2009 ... HELLO THERE The silver eagle d104 is wired just the same as the knight ...
astatic echomax 2000 unilli eagle wiring · wiring diagrams for ... http://www.fixya.com/support/t3271236-am_needing_wiring_desc... - 125k - Similar pages
14helpful
6answers
Cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
2helpful
I need the wiring diagram for A silver Eagle mike to a Ranger 2950 DX
1 shield & blue
2 white
3 red
4 black
5 n c
6 n c
yellow.. n c
Top Ranger Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
