Computers & Internet Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cd rom drive sr243t1 series-is this item still in production
Acer lap-top / purchased in 2002
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on May 31, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555106
Points
31058
ACER stocks parts for "discontinued" laptops, but they are VERY expensive.
Take your computer to a qualified technician, who can replace the CD-drive with an less-expensive "generic" replacement, and perhaps add DVD read/write capability.
2answers
I have a new lap top without cd reader. Also have product key for office 2003 pro but only on CD. How do I get it on my new lap top?
Hello.
Unless you can borrow an external CD drive with a USB connector, you would need to contact Microsoft and give them your Office 2003 key and they may allow you to download a copy.
Actually, it might be worth it to purchase an external CD drive. I've seen them priced from $20 - $100.
Hope this helps.
How can i use ltc-48161h dvd-rom without PC? i have cabels
You need to purchase a 5.25" external enclosure with the same connection type as your drive (which is IDE). You install your drive into that enclosure and then use the drive via USB. The enclosure will have all the cables you'll need. I recommend this one = http://www.newegg.com/Product/Product.aspx?Item=N82E16817145050
1helpful
My cd drive in lap top is not working.My LAPTOP MODEL IS 4720Z.it is no ejacting it is not working completely.
this is amoter' rubber problem . we can see in old room.take it on tecn . they can change.
Sreen probems
Try hooking up your lap top to an external monitor. If does the same thing, then more than likely your graphics card is shot. Unfortunately this is built into the motherboard and you will probaly have to purchase a new motherboard. There are a couple of things to try first. 1. Remove the memory and reposition and see if that helps. 2. remove hard drive and battery and try powering up.
Fujitsu lap top cant find cd rom so i cant load softwear
Go check your BIOS to make sure the cd rom drive is recognized by the system first, as if it is not, you will not be able to use it.
If the cd drive is removable, try removing it and reinstalling it first.
If the drive is recognized press the F12 key to get into the boot selection and choose CD Boot.
I hope this helps.
Good Luck.
Havin to use online keyboard as keyboard on my lap top not workng
If an external keyboard works, than you should try reseating the laptop keyboard cable. If that doesn't work the keyboard will need to be replaced.
Drive E
does the pc recognise the cd drive , if it does but still not recognise the disk,s then its maybe faulty , replacement dvd drives are soo cheap , £25 ans easy to fit , if you can not see the drive in "my computer" the click start.right click my computer,click properties.click hardware and then device manager.scrool down ,look for dvd/cd rom drives or any yellow question mark???, click item and properties and go from there ,
2answers
Dvd rom problems
CDROM CAN NOT READ CD'S Try cleaning the lens using a high grade CD Lens Cleaner. Sony\ACER\BENQ Lens Drives are notorious when it comes to compatibility. Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
