Quicksilver Quiksilver Windy Digital Watch Logo
A
Anonymous Posted on Jan 15, 2014
Quicksilver windy watch can't set time - Quicksilver Quiksilver Windy Digital Watch
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
How do you set the time on a watch with 4 buttons but no crown
Make and Model helps in questions like this.
4 Button Digital Watch
PDF4PRO https://pdf4pro.com > cdn > 4-button-digital-wa... PDF 4 Button Digital Watch. SETTING NORMAL TIME. • In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, ...
1 page
How to Set the Time and Date on a Digital Watch
wikiHow https://www.wikihow.com > ... > Jewelry > Watches
10 steps
1.
Read the labels on the 4 buttons on your watch. If you can't look up a manual right now, you can probably figure out how to change the time with some simple ...
2.
Press the "Mode" button or hold it down until the time flashes. The minutes or hours of most digital watches blink when you're in the time setting mode. On ...
3.
Use the "Start/Stop" button to change the individual numbers. Once you get the minutes or ho
Jul 22, 2022 • The Watches
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 • Watches
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
How do i change the DATE ( on top right of watch face ) on the QUICKSILVER ACCENT DIGITAL WATCH for men ?
You will need to pull out adjuster and turn to
right or left depending on the date you have on it.
Today 11th so if on 1st turn clockwise until you get
to 11th.
LUCK
Oct 11, 2014 • Watches
I have a new windy watch but dont know how to set the date and time on it could anyone please help me?????
annoyingmist, let me try.
1.by windy you mean mechanical?
2. if yes, then move the hands clockwise watching the calender until new date appears.
3. now turn hands anti- clockwise a little and clockwise again. Keep doing until you get today;s date.
4. set the watch to correct time. good luck.
Dec 25, 2013 • Watches
Quicksilver arcade watch alarm
Hey Malcolm, just bought this watch so I hope it is the same. Press the MODE button (bottom left) until you get AL. Then press the STAR/LAP (top left) this gives you the options of turning it off : ON with Alarm or ON with Alarm and CHM (I think this is the hourly chim) or OFF. (Located above the Quicksilver brand mark) Hope this helps!
Carla
Nov 24, 2011 • Watches
Where can i get a manual of my quicksilver traction watch?
I looked at the Quiksilver web site but could not find the model you have.
If you go to thier web site http://www.quiksilver.com/family/index.jsp?categoryId=2978686&sr=1&origkw=watches, you will see a list of watches and clicking on one of them will take you to a page that has "manuals" near the bottom.
Click on this and you will see a heading "analogue watches" but there are no instructions for digital types. If you watch is a digital watch, then I can only suggest that you contact them and ask them to send you a copy.
Feb 01, 2011 • Watches
5helpful
2answers
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 • Watches
Top Quicksilver Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Quicksilver Watch Expert? Answer questions, earn points and help others
