Sony 1GB Memory Stick PRO Duo Memory Card Logo
Anonymous Posted on May 28, 2009
I cannot formate my sony 1gb memory stick pro duo when i inserted in my computer it shows it cannot use it before formate disk when i tried to formate it shows window was unable to complete the format
Anonymous
Level 2:
Scholar:
  • Expert 100 Answers
  • Posted on May 28, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
100
Questions
0
Helped
46916
Points
289
Windows formatting tools are not good enough to format Sony memorysticks.
You need to use special formatting tool
Download that from here:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=MSACUS40&upd_id=2860&os_id=7
If this will not be able to format your memorystick - call sony support and report that repair of memorystick is necessary. It is a hardware fault with memorystick and it needs to be repaired or replaced.
Anonymous
Level 2:
  • Expert 39 Answers
Anonymous
Expert
Level 2:
Answers
39
Questions
Helped
16461
Points
104
Please contact your dealer to either get it replaced. or go buy a new card. they cost basicly nothing...
3 Related Answers
Anonymous
  • 952 Answers
  • Posted on May 17, 2009
SOURCE: formate memory stick
try formating the card using a digital device such as a camera or a playstation portable (PSP)
Anonymous
how can i formate memory stick pro duo 1gb
Anonymous
  • 828 Answers
  • Posted on Jul 17, 2009
SOURCE: i cannot formate my sony gb memory stick pro duo
its totally damage your sony gb memory stick pro duo buy a new one...
My pc does not read the memory stick PRO duo sony...
my memory pro duo in camera show picture , when it conect with computer ,picture no t show.how can i do?
How do I format my pro duo memory stick. I have xp.
Insert in card reader.
Bringup "Computer" on screen, right click Mem Card Icon, menu should show "Format".
When i turn on my camera it appears "error formating memory stick"
I inserted adapter and memory stick in my sony cyber shoot camera and keep getting format error. How do I format the memory stick
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 0helpful
    1GB Memory Stick PRO Duo Memory Card: My sister's boyfriend put my stick into his comput...
    Preformat : By Fix-shad0w
    #1
    #2
    #3
    #4
    #5
    #6
    With A USB , CELLPHONE , Camera The SameThing
    2answers
    Memory stick pro duo
    LLFTOOL is a utility for low-level disk drive formatting,
    also supports formatting of FLASH cards using a card-reader.
    1. Download this tool:
    http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
    2. Format stick pro duo
    (WARNING: After running this low level format tool,
    the whole USB flash disk surface will be fully erased.
    Therefore, data restoration will be impossible after using this utility!)
    11helpful
    4answers
    Formate memory stick
    2answers
    Memory card error
    did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
    CHARCOIS
    Top Sony Electronics - Others Experts
    Sean Wright
    Sean Wright
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
    Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
