SOURCE: Amana af12538aes Refigerator No lights, ice, water
There's no ice
If your ice maker has stopped producing ice completely, check these, in this order:
Small or too few ice cubes
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Specks in the cubes
If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Fill ice maker with tap water and allow the water to
freeze. If when the ice maker cycles and drops ice into ice bin it chooses not
to refill with water at end of the cycle. That would point to the dual water
control valve. If ice maker does nothing when filled with tap water that will
indicate a defective ice maker. The model number you listed does not appear to
be correct. Look around the fresh food section door frame and see what you
have. This could be the ice maker or the dual water control valve causing this
problem. Thanks Sea Breeze
The manual has nothing about how to reset this indicator. We have tried power cycling the fridge, system check, etc. The light keeps blinking though the door is completely closed.
