Home Logo
A
Anonymous Posted on Jan 14, 2014
Roca toilet Seat won't stay up
2 Related Answers
Billy Detlefsen
  • 159 Answers
  • Posted on May 08, 2010
SOURCE: i have a roca dama toilet seat which needs
Don't know about a roco dama, but most have color coded plugs where the screws go in, you will need to look alittle harder.
Anonymous
  • 1238 Answers
  • Posted on Jul 15, 2011
SOURCE: Kohler elongated toilet seat. Seat
Good day!!!!
If the toilet seat did not stays up you need to adjust the seat for at least more than 90 degrees like 95 or 100 degrees with the base while stays up...
if you think that model is don't have enough clearance to to stays up and if wish get another one please try this..
http://www.us.kohler.com/onlinecatalog/category.jsp?category=14
you can select by features like elongated or bowl shape and if it seat style,close or open front or even the color..
Roca Toilet dual flush buttons
buttons incorrectly marked
Aug 06, 2021 • Home
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 • Home
Roca dama senso
Hi
yes with an Allen key no problem as the screws are fixed in a plastic plug that wont fall through. See replacement video here
https://www.youtube.com/watch?v=bzIM_aGTRFY
Nov 04, 2017 • Home
How to fit replacements roca soft close hinges on a toilet
These hinges are completely replaceable and I sell them. Here is a step-by step manual how to do it yourself:
http://roca-parts.eu/roca-softclose-repair/
Sep 24, 2011 • Home
The bolt covers for the toilet seat will not stay closed. What do I do?
mcdevito75 here, Possibly replace the bolt covers as they could be stretched or just leave them off.
I have a roca dama toilet seat which needs tightening but see no way to open the sealed unit
May 07, 2010 • Home
3helpful
2answers
Toilet seat
Here's what I did. Unscrew them as much as possible. Then I used a bolt cutter and hacksaw to cut away as much of the plastic seat holders as possible. I could then remove most of the seat, and get better access to the screws. I then raised the loose screws enough to cut them with a bolt cutter. Soft screws cut easily. The screw heads are now out. Now, tap down on the screw/anchor and it falls into the bowl. It will stay there. The remaining problem is that you need anchors to secure the new toilet seat. Kohler wants $50. I have a usable but loose seat. Never again-Kohler.
I strongly recommend using a boltcutter. A hacksaw will tear up the bowl.
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
