i-mate Jama 101 Smartphone Logo
A
Anonymous Posted on Jan 15, 2014
Www fixa com
My phone rings only 2 times and goes to voicemail. How do I make sure that is rings at least 4 or 5 time for a call?
I need to extend the length of time my phone rings on incoming calls
Hello, Mary -
I checked the user manual for your Alcatel 3003G cell phone:
https://www.manualslib.com/manual/1150047/Alcatel-Tribe-3003g.html?page=1#manual
I did not find any information regarding increasing the length of time of rings of incoming calls in the manual. So, I thought the incoming rings length of time may be dependent upon your cell phone service provider, Vodafone.
I found some information on a Vodafone Support page:
https://support.vodafone.co.uk/
How to increase the time before a call goes to voicemail?
(Quote)
Your Vodafone mobile is set to ring for 15 seconds before going to voicemail. You can change how long it rings for, choosing from 5 to 30 seconds in 5-second intervals.
To choose your desired ringing time:
  • Enter **61*121*11* on your Vodafone mobile
  • Choose the number of seconds you'd like your phone to ring for, followed by #
  • Press Call
  • A confirmation message will pop up on your screen with your new ring time
For example, if you want to set your Vodafone mobile to ring for 25 seconds, you enter **61*121*11*25#, and press Call. When the message pops up, you'll know it's all done.
Watch this simple video to find out how to increase the time before a call goes to voicemail.
https://youtu.be/rGJNpaaD5z8
(End quote)
Best wishes.
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
2helpful
I just wanted to ask how to shorten the number of rings before it goes to voicemail on a t7316 and t7208 phone. Thanks
You may need a tech if unsure of programming, passwords and navigation.
In Config or Admin under Sets/Capabilities you will see Forward No Answer, that needs to be pointed to the voice mail ext # (F985 to see what that is), then after that setting is the ring count....4 is recommended for average office staff.
Our phone only rings 4 times before it goes to voicemail.
Depending on your phone ,but you should be able to adjust it in your setting and that is in your phone menue
3helpful
2answers
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 • Cell Phones
Voicemail timestamp & "on hold" too long
Yes Music can be played from your system during transfer. Simple connect any radio or cd player to the RCA jack located on your KSU (main box) For setting the time in voicemail log into box 999 with sec code 999997 or just 997 and press 8 for admin features. More guides and ACTUAL manuals can be found here
http://guides.idacomusa.com/
1helpful
2answers
I need to change the number of rings before phone goes to voicemail
First, call your voice mail. After the messages you will be given a menu to follow. On the Sony Ericsson W350 I went to Personal Options (4) then to Administrative Options (2) and finally Prompt Level (3). After reaching Prompt Level you have the option to shorten or extend the number of rings. At this point I chose to shorten the prompt and then I exitted the system.
Top i-mate Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
