Electrolux EW1000i Front Load Washer Logo
A
Anonymous Posted on Jan 14, 2014
Electrolux ew1248w diagnostic codes
1helpful
My Electrolux washing machine is blinking red with no time separator, can you help diagnose the problem. my model number is EWM09312
Here are some steps you can follow to try and identify the issue:
Check the Door: The start button on your Electrolux washer may start blinking if the door to the washer is not closed properly. Try opening and closing the door again to see if the button stops blinking.
Error Code Display: If the light only appears red, you can try the following manipulation to display the error code:
Turn on your washing machine
Simultaneously press the start button and the one to its left, usually the "end of cycle" button
After a few seconds, the error code should be displayed
Service Manual: For a more comprehensive diagnosis, you might want to refer to the service manual for your specific model.
It contains a guide to diagnostics of electronic controls and troubleshooting based on alarm codes. ELECTROLUX EWM09312 SERVICE MANUAL Pdf Download ' ManualsLib
Technician may have to replace PCB.
How to enter diagnostic mode on Electrolux ewmgd70jppo
Please follow these procedures to activate the diagnostic mode on an Electrolux EWMGD70JPP0 dryer:
Ensure that the dryer is unplugged from the power source and turned off.
The "CANCEL" and "START" buttons should be pressed and held simultaneously.
Reconnect the dryer's power while continuing to hold down the "CANCEL" and "START" buttons.
Holding the "CANCEL" and "START" buttons together will start the diagnostic test.
That should only take a few seconds.
Once the diagnostic test has begun, let go of the "CANCEL" and "START" buttons.
Now that you should be in diagnostic mode, you can go through the various tests using the display.
The "CYCLE SELECT" knob and the "OPTIONS" button should be used to cycle through the tests, respectively.
The diagnostic mode should only be used by those who are qualified to work on appliances, as it is designed for service technicians.
It is advised that you get in touch with a reputable appliance repair provider if you are unfamiliar with the diagnostic mode or are unclear on how to proceed.
I have a 7 year old top of the line Electrolux dishwasher and during the wash cycle it stops and beeps (120 time) . Does anyone know if this is a control panel issue?
It could be anything. They have a diagnostic brain that creates beeps or codes, but never hear of one that beeps 120 times.
You can try power cycling it. Remove mains power for 2 minutes and try again. If that doesn't fix it you will need a service call. If it is the control board, you may consider a new machine is a better option.
2answers
Electrolux front-loader motor doesn't spin - error code EF4
most likely worn out brushes on the motor or faulty motor
1helpful
2answers
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
1helpful
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
