I just bought a totally wiped out dell inspiron 8000 from my work, and i have the windows vista disks that i have from my desktop, my question is since i dont have an operating system is the windows vista compatible with the dell inspiron 8000? would i use recovery cd or boot cd?
First, if you are still running Vista on your desktop then you will need to buy a license for the laptop. Does the laptop have a WinXP on it now? If so, go here http://www.microsoft.com/windows/windows-vista/get/upgrade-advisor.aspx and run the Vista Upgrade Advisor. If not, determine the hardware specifications of your laptop and go here http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx Compare your laptops specs to those listed for the version of Vista you wish to install.
Sorry dagcg2, I missed that the hard drive was wiped. When you power up the laptop watch the screen carefully, it should tell you how to get into the BIOS, usually F2 on Dells. You may not need to change anything. If the CD-ROM is already in the boot list then the machine will search there if it can't find a boot device that is above it in the boot list. Doesn't hurt to put the disk (either one) in and give it a shot.
No, you can not use vista here. Xp should be slow but ok.
1 GHz 32-bit (x86) or 64-bit (x64) processor
1 GB of system memory
40 GB hard drive with at least 15 GB of available space
Support for DirectX 9 graphics with:
WDDM Driver
128 MB of graphics memory (minimum)
Pixel Shader 2.0 in hardware
32 bits per pixel
DVD-ROM drive
Audio Output
Internet access (fees may apply)
These are must for the pc, that can run vista. That is a P3 processor with 8 times less memory then it need. How cas someone say, it will run ? do u think, it will run ?
Please reconsider the rating you game me and the people who really looked the pc model and tried to solve your problem.
if you do not want to buy an OS, try linux. its fine and free.
And there are ways to use windows without buying..i must not mention it here lol.
YOUR SYSTEM IS NOT AT ALL COMPATIBLE WITH WINDOWS VISTA.
Make sure u install Windows XP.
You Need Not Change The Boot Sequence Follow These Steps For Windows Re-installation..
Process for Windows XP Re-installation
1. Insert Windows XP operating System Disk In The CD Drive.
2. Shut Down The system.
3. STEP 3 IS MEANT ONLY FOR DESKTOP SYSTEM.
Disconnect Everything Except Mouse, Keyboard, Monitor And Power Cable
i.e. something like internet, printer, USB PEN DRIVE or External Hard
Drive.
4. Restart your system and start tapping F8 key on the keyboard until the DELL LOGO passes from the screen.
5. You will be seeing the BOOT DEVICE MENU.
6. Choose the option--> CD-ROM DEVICE or BOOT FROM CD-ROM.
7. When u highlight it and hit enter on it, the screen will show you PRESS ANY KEY TO BOOT FROM CD.
8. Hit enter Immediately on that screen without missing it otherwise all the step will be repeated back.
I'M ATTACHING FEW LINKS FOR YOU SO THAT YOU CAN DO THAT EASILY AND
LEARN AS WELL SO THAT YOU MAY HELP OTHERS AS WELL. SO YOU JUST HAVE TO
COPY AND PASTE THE LINKS GIVEN AFTER EVERY STEPS TO DO EVERYTHING SO
EASILY.
9. Next screen will show --> WINDOWS SETUP,
Set up is inspecting your hardware configuration AND THEN set up is
loading files.
http://content.techrepublic.com.com/2346-10878_11-5181-1.html
10. When u see the WINDOWS XP PROFESSIONAL SETUP SCREEN.
http://content.techrepublic.com.com/2346-10878_11-5181-2.html
To set up WINDOWS XP now, press ENTER.
11. On the LICENSE AGREEMENT SCREEN hit F8 to accept the LICENSE AGREEMENT.
http://content.techrepublic.com.com/2346-10878_11-5181-3.html
12. Now the Screen will show u the EXISTING PARTITION on your computer so select one at a time and then hit D to DELETE the partition and if it askd for confirmation then hit ENTER to confirm DELETION of the partition. Delete all the EXISTING PARTITION until you see just UNPARTITIONED SPACE.
http://content.techrepublic.com.com/2346-10878_11-5181-4.html
13. When all the partition are deleted then HIT ENTER to INSTALL.
14. The next screen will ask u to CREATE PARTITIONS
so its up to u how many partition u will create. Well i will strongly
recommend 2 or maximum 3 partitions. So choose the size accordingly.
Create C PARTITION of 20480 MB.
http://content.techrepublic.com.com/2346-10878_11-5181-5.html
15.
When u r done with creating partition then just hit ENTER on the NEXT
SCREEN and make sure that the HIGHLIGHTED PARTITION IS C ON THE SCREEN.
http://content.techrepublic.com.com/2346-10878_11-5181-6.html
16. Now you will see the FORMAT PARTITION SCREEN so choose the option FORMAT THE PARTITION USING THE NTFS FILE SYSTEM.
http://content.techrepublic.com.com/2346-10878_11-5181-7.html
17. Now time to GET SOME TEA OR COFFEE DUDE because now you will see the SET UP IS FORMATTING THE PARTITIONS so we have to wait few minutes.
http://content.techrepublic.com.com/2346-10878_11-5181-8.html
18. Next Screen Will Show u that SET UP IS COPYING FILES with a moving yellow bar.
http://content.techrepublic.com.com/2346-10878_11-5181-9.html
19. Keep yourself busy with the COFFEE MUG DUDE.
http://content.techrepublic.com.com/2346-10878_11-5181-10.html
20. Now u juss have to sit and relax for next few minutes.
http://content.techrepublic.com.com/2346-10878_11-5181-11.html
21. Get one more coffee for yourself my friend.
http://content.techrepublic.com.com/2346-10878_11-5181-12.html
22. On the Regional and Language Options Screen you just have to click on the NEXT BUTTON on bottom right hand side.
http://content.techrepublic.com.com/2346-10878_11-5181-13.html
23. On the next screen you need to fill the required details as you would like my friend and then click next.
http://content.techrepublic.com.com/2346-10878_11-5181-14.html
24. The next step may or may not come in your screen which is to enter the PRODUCT KEY for the WINDOWS XP
as we will use the OPERATING SYSTEM DISK which i believe u must have
got from dell but in case you got this screen enter the PRODUCT KEY and
click next. It would be located on the DISK COVER or on the BACK OF
YOUR DELL DIMENSION 4600 on a WHITE BAR CODED STICKER AND IT WOULD BE
OF 25 DIGIT ALPHANUMERIC.
http://content.techrepublic.com.com/2346-10878_11-5181-15.html
25. The next screen is of Computer Name and Administrator Password. You just have to enter the Computer Name and leave the Administrator Password Box blank and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-16.html
26. The Date And Time Settings screen will come up so kindly choose the correct date and time settings with TIMEZONE.
http://content.techrepublic.com.com/2346-10878_11-5181-17.html
27.
Now the time will come when you may go and have a burger because this
process will take nearly half hour and will keep showing you its
progress my friend.
http://content.techrepublic.com.com/2346-10878_11-5181-18.html
28. Network Settings Screen don't bother yourself and concentrate on the burger and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-19.html
29. Workgroup and Computer Domain Screen so click next only.
http://content.techrepublic.com.com/2346-10878_11-5181-20.html
30. Display Settings or Resolution Screen.
http://content.techrepublic.com.com/2346-10878_11-5181-21.html
31. Don't even bother if these screen don't come up.
http://content.techrepublic.com.com/2346-10878_11-5181-22.html
32. Bill Gates Thanksgiving Screen. Click next.
http://content.techrepublic.com.com/2346-10878_11-5181-23.html
33. Windows Updates Screen. So choose first option.
http://content.techrepublic.com.com/2346-10878_11-5181-24.html
34. Click Next If u got this screen which most probably you will not.
http://content.techrepublic.com.com/2346-10878_11-5181-25.html
35. Internet Settings Screen. Choose the second option saying No this computer will connect directly to the internet and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-26.html
36. User Account Screen. Please quickly create the user accounts.
http://content.techrepublic.com.com/2346-10878_11-5181-27.html
37. Thank You Screen.
http://content.techrepublic.com.com/2346-10878_11-5181-28.html
38. Welcome User name Screen. So choose your user name and log in.
http://content.techrepublic.com.com/2346-10878_11-5181-29.html
39. WINDOWS XP RE-INSTALLATION COMPLETED.
http://content.techrepublic.com.com/2346-10878_11-5181-30.html
SO NOW YOUR NEED TO INSTALL THE DRIVERS FOR AUDIO, VIDEO, CHIPSET AND NETWORK
WITH THE DELL DIMENSION RESOURCE CD i.e. Drivers And Utilities CD. Or
visit the following link from any other computer and DOWNLOAD the
drivers and put it onto a USB PEN DRIVE OR A CD and then install it on
to your DELL INSPIRON 8000.
LINK FOR DRIVERS
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=INS_PNT_P3CG_8000
SELECT THE OPERATING SYSTEM AND DOWNLOAD THE DRIVER TO INSTALL.
SORRY FOR THE MISTAKE KINDLY PRESS F12 IN STEP4 INSTEAD OF F8.
I WOULD REQUEST YOU TO KINDLY FOLLOW THIS LINK BELOW AND SEE FOR YOURSELF WHETHER THE DRIVERS CAN BE DOWNLOADED FOR WINDOWS VISTA OR NOT FROM DELL'S OWN SUPPORT WEBSITE
http://support.dell.com/support/download...
plzz change your ratings accordingly
IF YOU INSTALL WINDOWS VISTA THERE WOULD BE NO DRIVERS AVAILABLE TO INSTALL ON YOUR COMPUTER....
HOWEVER IF YOU SOMEHOW INSTALL WINDOWS VISTA IT WILL AFFECT THE PERFORMANCE VERY BADLY AND WILL PICK UP ONLY THE GENERIC DRIVERS RESULTING IN POOR QUALITY OUTPUT AND PERFORMANCE.....
EVEN IF YOU CHECK IT ON MICROSOFT'S WEBSITE ABOUT BASIC WINDOWS VISTA HARDWARE NEEDS AND USER'S REVIEWS THERE WOULD BE DIFFERENCE OF AGES SO DON''T GO ABOUT INSTALLING WINDOWS VISTA...
If you wiped it off the hard drive, then you will need to use the boot cd because your computer will not be able to boot from a blank hard drive. You'll need to go into BIOS, and change your boot order so it will boot from the cd. then just let it run..good luck..
As long as the OS is good you can install it..then weill give you the activation key withen 30 days.. because this is not original in this unit....you can crack just download only crack from the internet..
. some cd's not compatible in another unit exclusive only in one unit..
thanks
You would use a boot CD. But do you have a valid key? Try getting a copy of the Windows 7 RC You will get 1 years use out of it and it will perform better than Vista
You use neither you would put in the windows vista setup disk and make sure your bios is set to boot from cd. Put in the windows setup disk turn on the pc and when it says "press any key to boot from cd" hit a key and it will take you into the windows setup. And technically any computer should be able to boot windows vista as long as it meets the min hardware spec posted on microsoft.com
it came without an operating system on it, how do i change my BIOS?
So some are saying it will work (vista) and some say that it for sure will not. Whats the deal will or wont vista work if i have a completely clean and clear harddrive if the model # helps it is pp01x...i just dont want to mess it up, but i dont want to buy a new operating system if i dont have to...
I ant to use recovery option for dell inspiron 15z which has the operating system win8.how can I start this
