I faced this problem in my system.....This copy of Windows did not pass genuine validation.what means this sentence obove? and what meas too by this sentence.downThe product key found on this computer is a Volume License Key (VLK) that has been blocked....hlep me please to get the solve...thank u to much... i have faced this problem in my system that....This copy of Windows did not pass genuine validation. The product key found on this computer is a Volume License Key (VLK) that has been blocked.please help me out
Issue - Windows is not genuine error !!
Solution - Activate your windows once again, in order to run genuine windows. To do that either you have to purchase the windows key or activate it via a tool. Another quick option is to take windows customer support help from here: +1888-315-9712
Read here the full process -
Activate windows via key
Hey Hi Shalin,
I believe u r not using the key that either is tagged with a branded system or on the cover of the WINDOWS XP DISK. Here, by Volume License Key (VLK) is meant that the PRODUCT KEY FOR WINDOWS XP has been used number of times and after that MICROSOFT has blocked it and it will work with the Computer from which it was registered.. In order to stop piracy MICROSOFT has done that, when a pirated version of windows is used online MICROSOFT record few details like MAK, Hard Drive Serial Number and few important details regarding the pc and on finding the PRODUCT KEY fraud they install WINDOWS GENUINE ADVANTAGE PLUG-IN into the system... If u have paid for the LICENSED VERSION of windows xp then contact the support person from where u bought it otherwise there are ways to remove it as well for that u can follow these steps....
FOR WINDOWS XP
THERE ARE NUMBER OF METHODS BUT FOR YOU THESE 2 METHODS ARE GOOD
1) METHOD:-
TRY SYSTEM RESTORE.
2) METHOD:-
2.1) LAUNCH WINDOWS TASK MANAGER.
2.2) End wgatray.exe Process In Task Manager.
2.3) Restart System In Safe Mode.
2.4) Delete wgatray.exe from c:WindowsSystem32.
2.5) Delete wgatray.exe from c:WindowsSystem32dllcache.
2.6) Launch RegEdit.
2.7) Browse the following key HKEY_LOCALMACHINESOFTWAREMICROSOFTWINDOWSNTCurrentVersionWinlogonNotify.
2.8) Delete The Folder "WgaLogon" and all of its component.
2.9 ) Reboot System.
3.0) BE HAPPY NOW.... AND NEVER EVER INSTALL WINDOWS GENUINEADVANTAGE NOTIFICATION IN WINDOWS UPDATE OTHERWISE YOU HAVE TO REPEATTHE DAMN PROCESS AGAIN.
IN ORDER TO THAT FOLLOW THIS
START--> CONTROL PANEL--> AUTOMATIC UPDATES --> CHOOSE THE OPTION """"""""""""Notify me but don't automatically download or install them"""""""""""
When u use this option whenever your system detects any new WINDOWSUPDATE choose the updates which u want to install... DON'T INSTALLWINDOWS XP SERVICE PACK --3.
If this doesnt work then follow this
{THIS IS THE LINK http://www.wikihow.com/Remove-Windows-Genuine-Advantage-Notifications}
STEPS TO REMOVE WINDOWS GENUINE ADVANTAGE
Right click on a blank space in System32 and select "New" > "Text Document".
Basically, what it means is that the serial number your Windows is using has been identified to be already used or invalid. This means that you will have to purchase a new Windows CD and reinstall your OS. If you do not know how, take it to a PC repair shop close to you and show them your problem.
You do not have a genuine copy of windows on your computer- If someone built it for you then you should contact them- if you put it on yourself then you are going to need to find another key somewhere or you will have to purchase it to get rid of the message
SOURCE: This copy of Windows did not pass genuine validation
When I tryed to execute Windows Update by internet connection, I followed all steps recommended by microsoft coorporation, afterwards in the last step of updating process it was display this message: This copy of this Windows did not pass windows genuine validation, you must be a victim of counterfeiting. What a sheme of Microsoft.
To buy another copy is too expensive for us.
Please help me to solve this problem.
Alfred from Albania
