SOURCE: Viking Dishwasher
Probable cause is either a bad fill valve, common with these, or just some debris in the fill valve inlet screen, also common. If you are handy you can take apart the fill valve and check the screen but often one needs to replace the whole valve, about an $80 part + labor. Double check your valve under the sink and make sure it is on completely.
SOURCE: Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
