Ink tape does not lower, so when typing no letters appear
There should be a little gear beneath the carriage you can turn, which will lower it:
http://cincinnatiprinterrepair.com/ibm-typewriter-ribbon-too-high
SOURCE: IBM Wheelwriter 1000 by Lexmark
The beeping problem is that spell check is on try code 1.
Pedro;
I'm not sure what your question is but it sounds like you are in caps. Try code C.
DickyO
SOURCE: How to change the Correction Tape For The Wheelwriter 1000.
Remove the ribbon there is a small latch on the ribbon that holds the ribbon and L/O together unlatch remove and reverse the process to replace.
DickyO
SOURCE: Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
SOURCE: The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Testimonial: "Thank you, very helpful."
SOURCE: WILL NOT TYPE
The keyboard is probably going bad. You can try my tip under WW1000 or contact Geo. Beyers Co. @ 1800-392-8085 for a keyboard rebuild. Tell them O'Reilly sent you.
DickyO
