Hi there. We have a Whirlpool LER4634J model dryer that now refuses to heat at all. We've noticed over the past few weeks that sometimes it'll take two cycles to dry thoroughly, but today there's no heat at all coming from it. We had a power outage last night for a few minutes. Does that have anything to do with it?
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
ELECTRIC Dryer no heat or little heat, or shuts down to fast: Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220, Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet. Test with a meter at room temperature and it should show continuity. A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
SOURCE: Whirlpool Dryer not heating
My electricity went yesterday and the city came out and flipped a breaker outside and the all of the electricity came back on and then the Heat started working on the dryer. I GUESS IT'S FIXED NOW.
Thanks for all of your help!!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
[p]
Dryer will blow out the thermofuse every time I replace it. The modal # is ler7646eq2
My whirlpool Dryer not heating at all
what should I do???
dryer turns on but doesn,t heat
Whirlpool Model #LER8620PWO - 3 years old - Runs but does not heat
Thermal sensor is a device that's less than $20 and is accessible from the rear of the whirlpool dryer. Has a white assembly with two wires coming out of it and is attached to the heat vent that evacuates thru the vent tube to outdoors. Locate that and replace it. About 8-10 screws will take the rear panel cover off and disconnect the vent tubing at the rear base...usually a spring ring or circular clamp holding it on. Replace thermal fuse, replace rear panel with screws and re-attach vent tubing. Done
