The fuel pressure drops to nothing while in use and dies....then it semms to not want to prime again suggestions ????
Also want to check the mixture numbers again
I can think of three possible causes that would be a good place to start looking:
- clogged tank ventilation, causing vacuum in the tank during use (check for this
when opening the gas tank cap, you should hear a "suction sound" and the engine should
prime and start afterwards)
- clogged fuel filter
- fuel filter/ fuel hose is not moving freely inside the gas tank causing it to **** air in some operating positions.
