MY BATTERY KEEPS GETTING DRAINED JUST BOUGHT ONE NOW THE LIGHTS TURN ON EVEN WHEN THE CAR IS OFF AND PARKED IT TURNS OFF AND THEN AFTER A WHILE IT TURNS ON AGAIN
SOURCE: 2004 Kia Sedona trying to find the starter.
it is located on the drivers side underneath the van. you have to remove it from the underside of the car. you will need a 17 millimeter socket or wrench. Remove the ground cable before attempting to remove the starter.
SOURCE: 2004 Kia Sedona wont start but i can hear starter.
if the starter is revving very slowly it is the battery, charge battery. if not, It can be three things happing. 1 no spark 2 no fuel 3 no crank signal or the car computer is bad- you will need to unplug one of the spark wires and remove the spark plug and put the spark plug in the spark plug wire boot, and touch the spark plug on any metal on the car and have some start the car. donot touch the spark plug itself and see if there is a spark. if spark is bright, then it is not spark plug and wires but if no or spark is not bright, check the spark plug wires by applying a little bit of water on the spark plug wire and take a 12v test light, connect the clap to ground and and have some one to crank the vehicle, touch allover the spark plug wires with the tip of the test light, if you see spark, replace the wires and change the plugs.. they are not good. if spark is present, check for fuel by removing any one of the spark plugs and see if it is wet. if wet fuel pump is ok but if not go look for the fuel pump fuse and relay. is fuse blown, replace, check the relay resistor with a volt meter. it should be around 40 to 80 ohm. if everything is good from this point check the fuel pump itself by disconnecting the connector to the pump and apply 12v and ground using jumper wires or some wires to the fuel pump if you donot hear the pump,replace pump. if you, the crank signal or computer may be the problem
SOURCE: 2004 Kia Sedona keeps stalling
Your problem sounds like you have a bad crankshaft position sensor. You will not get a trouble code (check engine light). This will cause the vehicle to suddenly stall. You cannot change the idle on this vehicle, or any FI modern vehicle contrary to a previous post. It is controlled by the engine management computer by way of an idle air control circuit on the throttle body.
SOURCE: car turns over but wont start it is a kia sedona
the car will not start if the immo light is not lit. sometimes turning the key back and forth or removing it and locking then unlocking the car can sometimes remedy this.
SOURCE: The button on my Kia Sedona gear shift is stuck
The button on my 2012 kia sportage gear shift is stuck. I cannot take the key out of the ignition or turn car completely off!
