I HAVE A 03 HUMMER H2 and I want to know how to get or downlod a FREE Service-Manual. . . .and/or how to get a Free Schematic Wiring Diagram for the H2.
THIS IS THE PAGE WERE YOU CAN DOWN LOAD THE OWNERS MANUAL 400 PAGES TOTAL. WWW.HUMMERXCLUB.COM/MANUALS/2003H2.PDF
SOURCE: I need to remove the luggage racks from my 2007 Hummer h2 SUT
I have the same vehicle and was able to remove mine with the following steps: 1) remove light behind each rear of luggage rack rail using phillips screwdriver (one screw each side). 2) remove molding underneath each light using T20 torx driver (2 screws each side). 3) Loosen cross rails nobs. 4) Side cross rails off of roof.
SOURCE: 03 H2 HUMMER WONT START
Does your scan tool have a reset eeprom mode?
if not, try disconnecting the battery for a 30 min period, then try
SOURCE: change light on 2006 hummer h2
it can be easily changed by removing the plastic cover then u will see the light bulb, don't try to change it from the back, it wont open :)
