Either your defrost is set wrong or it's not working,
try this , totally defrost the fridge ,once this is done turn it on , a small fan should be running in the freezer section , if it's not then this is the primary cause, if it is then your defrost is not working in which case you will need a new one. There is only one more thing to check and that is the thermostat .
once the fridge has reached temp or close to it, try turning the thermostat to a lower number then back again , if it turns the comp on and of or at least makes a click sound then it's ok, if it does nothing then this could be the issue.
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Determine the temperature setting. The refrigerator should be set to temperatures ranging from 34 degrees to 40 degrees, while the freezer should be below 30 degrees. Adjust the temperature setting which will naturally improve the ice buildup that's been caused by the wrong temperature setting.
Move the refrigerator away from the wall. Oftentimes, this simple action is all that is needed because the unit is not getting enough air circulation behind it. Also, some refrigerators have vents underneath the unit, which are easily clogged with debris. Clean these vents and coils.
Remove food and shelving from the refrigerator and freezer portions of the fridge. If ice build up is happening in the freezer, the drain in the freezer may be clogged. With the unit off, remove coverings to expose drain and pour hot water down the drain hole until it comes out into the drain drip pan under the fridge.
Check the condenser coils. The evaporator coils could be causing the problem of ice build up. If this is the case, professional repair is likely needed to replace the motor, thermostat or other problems within the fridge.
Check this link for a detailed idea:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query or else please accept the solution.
