HOW TO FIX
SOURCE: Red "wrench" indicator always on
Press the clear and the 8 button at the same time . This will give you a error code. I will guess that you have a "C7". If you still want to fix let me know error code.
SOURCE: Toshiba 1360
TOSHIBA 1210 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
SOURCE: Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
SOURCE: i have a toshiba 1370 copier....the repair wrench
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
