3Com WX2200 (3CRWX220095A-US) Wireless LAN Controller Logo
M
Mister Posted on Jan 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recovery password 3com wx2200
How to recovery password admin user without loss configutarion?
Level 3:
  • 3Com Master 7,733 Answers
  • Posted on Apr 07, 2014
3Com Master
Level 3:
Answers
7733
Questions
0
Helped
1864823
Points
21487
Try this http://www.fixya.com/support/r11153882-general_routers_reseting
2answers
Forget administrative password
It's common that an Acer computer user often happens to forget his or her admin password. Here I find a professional tool to reset windows passwords. It's called "Windows Password Key". It can reset any windows login passwords including user or admin passwords without any data loss. More information you can visit http://www.lostwindowspassword.com/
8helpful
3answers
How to do if locked out of Windows 8 laptop?
1. Run "lusrmgr.msc" to reset Dell Windows password.
In Windows 8/7/Vista/XP, there is an easy way to reset a forgotten user account password by just run the lusrmgr.msc. But you need to login your server or laptop with an account which has admin privileges. Note that resetting password with this tip might cause irreversible loss of information for the user account. This data loss will occur the next time the user logs off. You should use this command only if a user has forgotten his or her password and does not have a password reset disk.
Step 1. Start your PC and log on with an available user account which has admin privileges.
Step 2. Click "start" button, press "Win+R" to open "Run box". Type in "lusrmgr.msc" and hit Enter.
Step 3. Local Users and Computers appears, all user accounts of your computer will be list, right-click your user name and select "reset password".
Step 4. Type in a new password and type it again to confirm it, click OK.
After restarting you can login that user account with new password.
2. Remove Dell password by using a Windows password recovery tool.
This is a universal way to reset forgotten Windows password on HP Server or PC, no matter what your Windows system is, Windows 8/7/vista/XP. iSunshare Windows Password Genius is designed to recover Windows password for any kinds of PC, such as hp, dell, acer, Toshiba, Lenovo, IBM etc. It not only can help reset server or laptop password Windows 8, but also Windows 7, Vista, XP and Windows 2000.
Step 1: Download and install Windows Password Genius Advanced on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk with CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your PC or Server and set the laptop to boot from the disk by changing devices boot order in BIOS SETUP.
Step 4: After boot from the password recovery disk, Windows password recovery tool will start automatically and display a friendly window. Then you can reset whichever account password of your PC or Server by a few clicks.
Windows Password Genius also allows user to create new admin account for your Dell Windows system without logging. With this new user, you can login your Dell computer directly and access control panel to reset other user password.
1helpful
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
3helpful
LOOKING for 3Com OfficeConnect Wireless Router password. the default password was "admin" but somehow it is change and eveen after Reset can't change it
hi normally after a reset the user name is normally, (admin), and the password is normally (password)....hope this helps
4helpful
9answers
Lost admin password
Forgot windows admin password?Do not be so anxious. I know a tool which can help you bypass windows admin password, need not to reinstall the windows OS, its safely and easily.By using "Any Windows Password Recovery 3.0 " ,could be helpful.
Forgot password and system admin cannot get in to reset
Run your PC in safe mode. Log in as administrator. Now go to control panel user accounts and change password. Now restart your PC. If Administrator account ask you for the password then you need a password recovery disk http://home.eunet.no/~pnordahl/ntpasswd/
16helpful
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
