Computers & Internet Logo
Anonymous Posted on Jan 14, 2014
Second drive unable to initialize
The drive is available in BIOS but if I try to initialize the system tells me there is an e/a failure.
Florin
Level 3:
  • Master 733 Answers
  • Posted on Jan 15, 2014
Florin
Master
Level 3:
Answers
733
Questions
0
Helped
166444
Points
1640
boot with one live cd windows or linux and recover what you need then change the cables from the first one to the second one.
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
1helpful
How can I translate the motherboard beeps on startup
AMI Beep Codes
Beep Code Meaning
1. beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
2. beeps Memory parity error. The parity circuit is not working properly.
3. beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
4. beeps system timer not operational. There is problem with the timer(s) that control functions on the motherboard.
5. beeps Processor failure. The system CPU has failed.
6. beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
7. beeps Virtual mode exception error.
8. beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
9. beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
10. beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
11. beeps Bad cache memory. An error in the level 2 cache memory.
1 long beep, 2 short Failure in the video system.
1 long beep, 3 short A failure in the video system.
1 long beep, 8 short display test failure.
Continuous beeping A problem with the memory or video.
BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence.
For example, 1-2-3 indicates one beep, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes.
Click here for AMI BIOS beep codes.
4-Beep Codes
Beep Code Meaning
1-1-1-3 Faulty CPU/motherboard. Verify real mode.
1-1-2-1 Faulty CPU/motherboard.
1-1-2-3 Faulty motherboard or one of its components.
1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values.
1-1-3-2 Faulty motherboard or one of its components.
1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers.
1-1-3-2
1-1-3-3
1-1-3-4 Failure in the first 64K of memory.
1-1-4-1 Level 2 cache error.
1-1-4-3 I/O port error.
1-2-1-1 Power management error.
1-2-1-2
1-2-1-3 Faulty motherboard or one of its components.
1-2-2-1 Keyboard controller failure.
1-2-2-3 BIOS ROM error.
1-2-3-1 System timer error.
1-2-3-3 DMA error.
1-2-4-1 IRQ controller error.
1-3-1-1 DRAM refresh error.
1-3-1-3 A20 gate failure.
1-3-2-1 Faulty motherboard or one of its components.
1-3-3-1 Extended memory error.
1-3-3-3
1-3-4-1
1-3-4-3 Error in first 1MB of system memory.
1-4-1-3
1-4-2-4 CPU error.
1-4-3-1
2-1-4-1 BIOS ROM shadow error.
1-4-3-2
1-4-3-3 Level 2 cache error.
1-4-4-1
1-4-4-2
2-1-1-1 Faulty motherboard or one of its components.
2-1-1-3
2-1-2-1 IRQ failure.
2-1-2-3 BIOS ROM error.
2-1-2-4
2-1-3-2 I/O port failure.
2-1-3-1
2-1-3-3 Video system failure.
2-1-1-3
2-1-2-4 I/O port failure.
2-1-4-3
2-2-1-1 Video card failure.
2-2-1-3
2-2-2-1
2-2-2-3 Keyboard controller failure.
2-2-3-1 IRQ error.
2-2-4-1 Error in first 1MB of system memory.
2-3-1-1
2-3-3-3 Extended memory failure.
2-3-2-1 Faulty motherboard or one of its components.
2-3-2-3
2-3-3-1 Level 2 cache error.
2-3-4-1
2-3-4-3 Motherboard or video card failure.
2-3-4-1
2-3-4-3
2-4-1-1 Motherboard or video card failure.
2-4-1-3 Faulty motherboard or one of its components.
2-4-2-1 RTC error.
2-4-2-3 Keyboard controller error.
2-4-4-1 IRQ error.
3-1-1-1
3-1-1-3
3-1-2-1
3-1-2-3 I/O port error.
3-1-3-1
3-1-3-3 Faulty motherboard or one of its components.
3-1-4-1
3-2-1-1
3-2-1-2 Floppy drive or hard drive failure.
3-2-1-3 Faulty motherboard or one of its components.
3-2-2-1 Keyboard controller error.
3-2-2-3
3-2-3-1
3-2-4-1 Faulty motherboard or one of its components.
3-2-4-3 IRQ error.
3-3-1-1 RTC error.
3-3-1-3 Key lock error.
3-3-3-3 Faulty motherboard or one of its components.
3-3-3-3
3-3-4-1
3-3-4-3
3-4-1-1
3-4-1-3
3-4-2-1
3-4-2-3
3-4-3-1
3-4-4-1
3-4-4-4 Faulty motherboard or one of its components.
4-1-1-1 Floppy drive or hard drive failure.
4-2-1-1
4-2-1-3
4-2-2-1 IRQ failure.
4-2-2-3
4-2-3-1
4-2-3-3
4-2-4-1 Faulty motherboard or one of its components.
4-2-4-3 Keyboard controller error.
4-3-1-3
4-3-1-4
4-3-2-1
4-3-2-2
4-3-3-1
4-3-4-1
4-3-4-3 Faulty motherboard or one of its components.
4-3-3-2
4-3-3-4 IRQ failure.
4-3-3-3
4-3-4-2 Floppy drive or hard drive failure.
3-Beep Codes
Beep Code Meaning
1-1-2 Faulty CPU/motherboard.
1-1-3 Faulty motherboard/CMOS read-write failure.
1-1-4 Faulty BIOS/BIOS ROM checksum error.
1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard.
1-2-2
1-2-3 Faulty motherboard/DMA failure.
1-3-1 Memory refresh failure.
1-3-2
1-3-3
1-4-1 Address line failure.
1-4-2 Parity RAM failure.
1-4-3 Timer failure.
1-4-4 NMI port failure.
2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory.
3-1-1 Master DMA failure.
3-1-2 Slave DMA failure.
3-1-3
3-1-4 Interrupt controller failure.
3-2-4 Keyboard controller failure.
3-3-1
3-3-2 CMOS error.
3-3-4 Video card failure.
3-4-1 Video card failure.
4-2-1 Timer failure.
4-2-2 CMOS shutdown failure.
4-2-3 Gate A20 failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure.
4-3-3 Timer failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port failure.
4-4-2 Parallel port failure.
4-4-3 Math coprocessor.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
1helpful
Will not turn on. the light on the front and back
Could be anything. I would recommend a qualified PC repair person take a look at it.
Here are some things you my try in the interim.
1. PSU not supplying correct power - Replace PSU
2. RAM incompatibility - Restore previous RAM configuration
3. New hardware conflict. - Remove new hardware
4. BIOS failure - Try shorting the 2 BIOs reset pins for a second with power and Monitor disconnected. You need to know what you are doing here, or skip this procedure.
5. CPU overheating - broken fan or overclocked
6. Malware attack - Format and reload system if unable to boot with restore or back-up.
7. Hard drive failure - Test on another PC as secondary/slave drive. Do a full scan for malware attack if drive is working. Otherwise replace with identical size or you may lose your OS validation.
8. Blown MoBo fuse (rare) - Replace fuse
9. Short or open circuit on MoBo - You can't tell unless you are a tech.
10. Dust, insects or debris inside PC - Gently remove.
This is a general 10 step check. There may be many more , depending on your system and components. Some checks, such as electronic parts failure are way too difficult for the average person to find, so do the basics, then power off, unplug everything, Press the power button. Wait for at least 10 minutes then plug everything back in. This process should totally discharge any residual power in the capacitors and refresh any system components that might be hanging. A bit Techy, but some Components only need a pico-amp to remain in an active state.
Good Luck
2answers
Unable to determine the boot device. Drivers may not be initialized. Initialize using the BIOS utility, or check if the disks are connected properly.
You need to go into setup view you drive array sounds like you may have one bad drive or the raid array has dropped by moving drives around hope this is what is wrong then re initialize the drive array you need more help email me at mje.bend at live dot com
Initialize using the BIOS Utility .
3helpful
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
9helpful
2answers
Bios Beep code
Beep Code Manual, Better Than Gold Techies, American Megatrends Int. & Phoenix
(I'm IT, I use these codes to trouble shoot hardware issues at my job. Enjoy) cold.gif
BIOS Beep Codes
When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
The two most-used brands are AMI (American Megatrends International) and Phoenix.
Below are listed the beep codes for AMI systems, and here are the beep codes for Phoenix systems.
AMI Beep Codes
Beep Code Meaning 1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard. 2 beeps Memory parity error. The parity circuit is not working properly. 3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory. 4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard. 5 beeps Processor failure. The system CPU has failed. 6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode. 7 beeps Virtual mode exception error. 8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card. 9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty. 10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS. 11 beeps Bad cache memory. An error in the level 2 cache memory. 1 long beep, 2 short Failure in the video system. 1 long beep, 3 short A failure has been detected in memory above 64K. 1 long beep, 8 short Display test failure. Continuous beeping A problem with the memory or video. BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes. 4-Beep Codes Beep Code Meaning 1-1-1-3 Faulty CPU/motherboard. Verify real mode. 1-1-2-1 Faulty CPU/motherboard. 1-1-2-3 Faulty motherboard or one of its components. 1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values. 1-1-3-2 Faulty motherboard or one of its components. 1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers. 1-1-3-2 1-1-3-3 1-1-3-4 Failure in the first 64K of memory. 1-1-4-1 Level 2 cache error. 1-1-4-3 I/O port error. 1-2-1-1 Power management error. 1-2-1-2 1-2-1-3 Faulty motherboard or one of its components. 1-2-2-1 Keyboard controller failure. 1-2-2-3 BIOS ROM error. 1-2-3-1 System timer error. 1-2-3-3 DMA error. 1-2-4-1 IRQ controller error. 1-3-1-1 DRAM refresh error. 1-3-1-3 A20 gate failure. 1-3-2-1 Faulty motherboard or one of its components. 1-3-3-1 Extended memory error. 1-3-3-3 1-3-4-1 1-3-4-3 Error in first 1MB of system memory. 1-4-1-3 1-4-2-4 CPU error. 1-4-3-1 2-1-4-1 BIOS ROM shadow error. 1-4-3-2 1-4-3-3 Level 2 cache error. 1-4-4-1 1-4-4-2 2-1-1-1 Faulty motherboard or one of its components. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 2-1-3-2 I/O port failure. 2-1-3-1 2-1-3-3 Video system failure. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 I/O port failure. 2-1-4-3 2-2-1-1 Video card failure. 2-2-1-3 2-2-2-1 2-2-2-3 Keyboard controller failure. 2-2-3-1 IRQ error. 2-2-4-1 Error in first 1MB of system memory. 2-3-1-1 2-3-3-3 Extended memory failure. 2-3-2-1 Faulty motherboard or one of its components. 2-3-2-3 2-3-3-1 Level 2 cache error. 2-3-4-1 2-3-4-3 Motherboard or video card failure. 2-3-4-1 2-3-4-3 2-4-1-1 Motherboard or video card failure. 2-4-1-3 Faulty motherboard or one of its components. 2-4-2-1 RTC error. 2-4-2-3 Keyboard controller error. 2-4-4-1 IRQ error. 3-1-1-1 3-1-1-3 3-1-2-1 3-1-2-3 I/O port error. 3-1-3-1 3-1-3-3 Faulty motherboard or one of its components. 3-1-4-1 3-2-1-1 3-2-1-2 Floppy drive or hard drive failure. 3-2-1-3 Faulty motherboard or one of its components. 3-2-2-1 Keyboard controller error. 3-2-2-3 3-2-3-1 3-2-4-1 Faulty motherboard or one of its components. 3-2-4-3 IRQ error. 3-3-1-1 RTC error. 3-3-1-3 Key lock error. 3-3-3-3 Faulty motherboard or one of its components. 3-3-3-3 3-3-4-1 3-3-4-3 3-4-1-1 3-4-1-3 3-4-2-1 3-4-2-3 3-4-3-1 3-4-4-1 3-4-4-4 Faulty motherboard or one of its components. 4-1-1-1 Floppy drive or hard drive failure. 4-2-1-1 4-2-1-3 4-2-2-1 IRQ failure. 4-2-2-3 4-2-3-1 4-2-3-3 4-2-4-1 Faulty motherboard or one of its components. 4-2-4-3 Keyboard controller error. 4-3-1-3 4-3-1-4 4-3-2-1 4-3-2-2 4-3-3-1 4-3-4-1 4-3-4-3 Faulty motherboard or one of its components. 4-3-3-2 4-3-3-4 IRQ failure. 4-3-3-3 4-3-4-2 Floppy drive or hard drive failure. 3-Beep Codes Beep Code Meaning 1-1-2 Faulty CPU/motherboard. 1-1-3 Faulty motherboard/CMOS read-write failure. 1-1-4 Faulty BIOS/BIOS ROM checksum error. 1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard. 1-2-2 1-2-3 Faulty motherboard/DMA failure. 1-3-1 Memory refresh failure. 1-3-2 1-3-3 1-3-4 Failure in the first 64K of memory. 1-4-1 Address line failure. 1-4-2 Parity RAM failure. 1-4-3 Timer failure. 1-4-4 NMI port failure. 2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory. 3-1-1 Master DMA failure. 3-1-2 Slave DMA failure. 3-1-3 3-1-4 Interrupt controller failure. 3-2-4 Keyboard controller failure. 3-3-1 3-3-2 CMOS error. 3-3-4 Video card failure. 3-4-1 Video card failure. 4-2-1 Timer failure. 4-2-2 CMOS shutdown failure. 4-2-3 Gate A20 failure. 4-2-4 Unexpected interrupt in protected mode. 4-3-1 RAM test failure. 4-3-3 Timer failure. 4-3-4 Time of day clock failure. 4-4-1 Serial port failure. 4-4-2 Parallel port failure. 4-4-3 Math coprocessor.
15helpful
7answers
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
DVD DRIVE FAILING TO INITIALIZE
try to check for the DVD drive inside the BIOS system ... as soon as booting the Laptop click on the button Delete .. you will find the HDD drive .. try to look for the DVD Drive ..
Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
