Question about Necchi 3102 Mechanical Sewing Machine
My machine is currently seized up with a baby quilt on it. The needle is down all the way and will not budge. When I depress the foot pedal or turn the wheel, it sounds like it's going to take off a
This is a great machine and have not had any other issues with it.
  • Necchi Master
  • 1,388 Answers
Undo tthe needle to raise the needle arm ...this will allow you to get under and carefully cut away the jam....there really is no easy way, and you may have already damaged the fabric if it is in the feed teeth, so be slow and gentle.
Posted on Jan 15, 2014
2 Suggested Answers
SOURCE:
  • 166 Answers
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Posted on Jan 02, 2009
How do I set 8900 for free motion quilting? D4S mode and QB-S foot
To do free motion quilting on most machines, install a darning foot or free motion quilting foot, drop the feed dogs, set the machine to straight stitch. (Because FMQ requires you to manually maneuver the fabric, stitch length is moot.) If your machine has the feature, setting it to Needle Down will also help. When you stop sewing, the needle will stop while penetrating the fabric. This prevents you from accidentally moving the fabric while trying to adjust before sewing again.
Free Motion Quilting Beginner Tutorial 1 of 4
Jan 11, 2017 | Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Walking Foot Trouble
sounds to me like you are getting what I call "flagging" of the material... where a tiny bur or something catches the material and pulls it up. If possible increase the presser a bit on the presser foot. You might also have the wrong foot for the machine or simply a defective one.
Also when it does this... do you notice any bobbin thread on top of the seam?
Feb 25, 2013 | Baby Lock Sewing Machines
Bobbin thread shows on embroidery machine
Did you remember to put down the presser foot?
Nov 13, 2012 | Baby Lock Sewing Machines
It was working fine. Then stopped. When you depress the pedal the motor idles but the needle doesn't go up and down
it's possible that the foot pedal has gone out
check to make sure the power cord in inserted into the machine correctly & also the foot pedal
Apr 02, 2012 | Sewing Machines
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
No matter how hard I press down on the foot pedal my needle speed is super slow. The needle position indicator sometimes shows up when the needle is down and the needle continues it slow speed even when my...
is the machine easy to turn by handwheel? if not it may be seizing and needs servicing.
if the machine is free to turn by hand it sounds like your foot control is in need of repair or replacement - see a tech.
scott.
Jul 20, 2009 | PfaFF Sewing Machines
My Singer Quantum CXL seems to be jammed
Go to this site
http://www.singerco.com/support/us_warranty.html
search for a Service Center in your state, call them for how to send in the machine and how much it will cost for repair.
sewman7
May 05, 2009 | Singer Quantum XL-1000 Computerized Sewing...
I have a White 955 machine and I am trying to quilt with it. It works just fine when I am sewing just one piece of material to another but when I want to sew the layers of the quilt together the stitches...
I know this is strange, but make sure the pressure foot is down. When I quilt sometimes, after getting the bulk under the needle, I forget to put the pressure foot down or it get's knocked back up by the quilt and causes the same problem. Good luck.
Jan 04, 2009 | White Sewing 955 Mechanical Sewing Machine
Doesn't sew
Hi emnsam....please update your post with the complete Model Number in it's entirety and I will be able to advise you.
Jul 29, 2007 | Husqvarna Rose
Necchi 3102 Mechanical Sewing Machine Logo
46 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
