Whirlpool quiet partner 2 , not filling with water
First try resetting your error code if there is one from your manual, then try the below.Also check to make sure your thermal fuse is good as well then do below.
Try pressing normal wash -heat dry-normal wash-heatdry- normal wash-heat
dry- norma wash - heat dry. all the lights should come on. then after a
little bit. keep pressing start till disher washer gets back to normal
shut down. Sometimes this uses other features and opens contacts that are rarely used and recycles the processor in control panel reactivating stuck contact solenoids.If none of this works your control panel needs replaced cost 100 up to 200 dollars. Remember to rate my solution and this is how i earn my achievements here on FixYa.
