Washing Machines Logo
d
dylan brown Posted on Jan 14, 2014
How do i repair my viking water heater - Fisher and Paykel (IWL12)
2helpful
Viking Fridge VCBB536 defrost pan fills with water. Float has been replaced but not resolved problem
There are several issues that need to be checked. What mode is the deffroster set to? There are several modes to check. There is a heater coil under the pan to assist in evaporating the water from the condensation tray. If you are in a high humidity area the condensation could be from that. I have attached the service manual for that unit to this post. http://www.uncleharrywizard.com/NephewClub/wizardfrig/viking/viking-bottom-freezers/smr-0007---bottom-mount-536.pdf
Where is the heater on viking vcff036
Heater as in divider million strip? It's in the door strip. Defrost heater is in freezer. This model is a whirlpool built unit fyi
Eaton viking dryer
in 2020 I had a few repairs on my Eaton/Viking dryer ED314W429 1 - replace heater coil - replaced with GE coil kit P# WE25M27K
2 - replace snapped belt - replaced with part# WG03F00846
It takes a while to figure things out DIY, however it's running again..
This link helped me a lot with repair of the element. When I had to replace the belt it was 10x faster due to experience.
https://dontai.com/wp/2016/10/24/viking-auto-dryer-t-eaton-company-heating-element-replacements/
Let's keep these old simple machine running if we can! Cheers Gerald Calgary AB.
Oct 31, 2017 • Dryers
Defrost heater do not defrost creating poor air circulation
for starter call viking with your mod and ser #
there is a hinge recall on fridge door is covered by warranty regardless of age
it can cause the air channel from freezer to fridge to ice over due to too much humidity entering fridge
this stops cooling in fridge
the viking warranty starts from the day you took possession
defrost heater almost never
sounds like you need a better servicer
ask viking for other auth servicer in your area
gl
Viking 48 leaking water
There is a drain pan heater unless mfr before 2005. Call Viking parts for that heater kit and eliminate that issue . 8004889868
Water dispenser not working
I had the same problem. Your water line is frozen. Turn off your freezer and the water line will unfreeze and it will work. You can see about putting in a heater on your water line. There have been mixed reviews on whether or not it works. The water line just froze again, so I may try the heater.
The water line leading to the icemaker is frozen so the water can not flow into the icemaker
you will need to replace water valve, it's not completely closing and water is leaking a little, so it's frosted in the water line.
other choice is install heater on water line, on all new refrigerators it's installed.
viking repair in Los Angeles
Multiple sparks when igniting one burner
have a 1997 model 2470 viking pop up camper , has a shower in stalled where does the used water come out ??
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
