SOURCE: connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
SOURCE: vio and d-link wireless router dsl-2640u connection problem
hi
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
SOURCE: No internet connection
the problem would be your antenna, thats the only way it sends the wireless signal. you shoudl be able to get a cheap replacement. try the following stores:
www.tigerdirect.com
www.radioshack.com
SOURCE: d-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
SOURCE: I have a d link
Welcome to Fixya
Try to turn off/on the dlink router first. Reisntall the driver of your ethernet adapter. check your computer's IP address by going to command prompt and type in ipconfig. This is to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router. If you have 169.x.x IP address, Reboot your computer, router (if present) and broadband modem together, then re-test your connection. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
