Frigidaire FEB27S5A Electric Single Oven Logo
A
Anonymous Posted on Jan 14, 2014
Broil element is not reseiving electrik power
1helpful
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 • Ovens
Broil does not work
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Broiler wont light
the broil element
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 • Ovens
I have Whirlpool RBS305PDB16.The bottom broiler element will not heat up only the top.Any ideas on the problem?
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Frigidaire DGES388DS2 electric single oven
Did you reset the house circuit breaker that supplies power to the oven?
Broil element won't come on.
1. Cut power to the stove by unplugging or switching off at the mains.
2. Remove broil element and inspect for burnt or melted places, if you have multimeter, then check it for continuity, it shouldn't have more than about10 ohms resistance. Burnt-out element is easily replaced.
3. If element is good, then check for voltage at element terminals, it should be 220 volt AC ( with caution, after turning power back on and setting oven to broil).
4. If all above checks out, then the problem will require disassembling the appliance to investigate thermostat issues, relay, etc. It would be at this point that I would strongly consider putting in a service call!
My broiler doesn't work in my JennAir S136 range and I think the problem is the selector switch. How can I confirm this?
To do that you could check if the correct power is going to broil element.That can by TURNING OFF CIRCUIT BREAKER, remove door by opening to appx 30 degree position where is shold stay open,pull off door,remove broil element and attach a volt meter set to measure at least 240 volts ac and attach the meter leads to the wires on broil element, restore power set controls to broil and check for 240 vac at element. If 240 vac at element it's the element thats defective, if 240vac not present the selector switch is the problem, espically if bake works
Good luck,i hope this helps ya diagnose your oven
Gene
Jul 31, 2011 • Ovens
Frigidaire GLEB30S8CSB- the broiler doesn't work, all other functions are normal. What do I need to look at? Many thanks...
Unplug the oven.
Remove the oven racks.
Remove the bake element.
Be careful and not let the wires fall back into the holes when you remove them from the element.
Use a volt/ohm meter set for ohms or continuity to check the broil element terminals.
No reading is a bad element. If no reading replace the element.
If the element is good the control panel will have to be opened to check for power from the electronic control to the element.
Re-attach the broil element.
Access the control module for testing.
At this point you will be working with live high voltage.
Turn the power back on.
If you are not comfortable with that please call a service technician.
If you want to do it,locate the broil out put wire and the neutral wire on the control. Set the control for broil,place your meter leads on broil and "N".
No reading is a bad control module.
A good voltage reading will be a bad wire to the broil element.
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
