Please first refer the the table of contents of your product manual in order to find the section related to factory resetting. You can also call the product manufacturer and request the manual be emailed to you if you do not currently have it.
Hi there! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to help you. Please perform a hard reset on the receiver. To do a hard reset, you simply unplug the receiver from the power outlet it is connected to, leave it unplugged for 20 seconds, then plug it back in. The receiver reboot process takes about 5 minutes. Once the show is back on, try accessing your DVR again, if it is still not working, the receiver will need to be replaced. If this is still a problem, please feel free to email me at kimberly.escobar2dish.com with your account number so we can get this resolved.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Hello this is Matthew Gonzales with DISH Network customer service. With a 024 message, the best thing that we can do is hard reset the receiver. To do a hard reset, you simply unplug the receiver from the power outlet it is connected to, leave it unplugged for 20 seconds, then plug it back in. The receiver reboot process takes about 5 minutes. Once the show is back on, try accessing your DVR again, if it is still not working, the receiver will need to be replaced. If this is still a problem, please feel free to email me at [email protected] with your account number so we can get this resolved.
Are you still having problems with your 625 receiver? It sounds like you are getting a 024 error message. When you unplug the receiver and plug back in, do you ever get a 311 error message? If you are still having problems, the receiver may need to be replaced. I would be happy to further assist you if you would respond back to this site.
Are you getting an error message (024 or 311)? If you are still having problems with your receiver, please call 1-800-333-3474. We may need to replace the receiver. I hope this helps.
Try a hard reset, disconnect from outlet for 2 minutes. If that does not work, check to see if you get an error code, 311 or 024 and if so, your receiver needs to be replaced. Call Dish!
The 024 message means the hard drive itself is having problems functioning correctly. Try a hard reset where you unplug the receiver for 10-15 seconds and plug back in. If the problem persists a replacement may be necessary.
Cause This message is displayed when a feature that relies on guide
information such as Themes, Timers, DVR Events etc. is being used and the
receiver does NOT have access to the guide information.
Power off the receiver and unplug the receiver from the electrical outlet.
Wait 10 seconds, plug the receiver back into the electrical outlet and power the
receiver on.
these error msgs indicate HD failure. your recr will need to be replaced to correct this issue. If you replace the drive yourself you can still ahve these problems, it is recommended to get a replacment from dish themselves.
