Exercise & Fitness Logo
A
Anonymous Posted on Jun 08, 2017
Tramping noise I have a new Nordic Track T 7.2 treadmill. Since the beginning I have noticed that it is making a disturbing noise when I am running on it, like I am tramping on every step. The noise is loud, I don`t think it is normal. When I am walking, it`s ok. The noise it`s only because of the running step. I am not extremely heavy (73 kg), so I don`t think it`s because of me. Please, help me, the noise is stopping me use it when someone else is at home because it`s very annoying.
5 Related Answers
joboo1
Jim London
  • 257 Answers
  • Posted on Mar 25, 2009
SOURCE: my Nordic Track E 4400 treadmill sqeaks loudly when in use
Hi again, OK thanks, The belt slides on a track and can get debris or other things that stick and is probably causing the squealing. There are belt cleaners and dressings and lubricants but the best place and the best product for your treadmill can be found at this site:
www.TreadmillDoctor.com They offer many bits of advice and how to on many different kinds of treadmills and can tell you how to clean and apply their product. Good Luck to you, this should Fixya!
Anonymous
  • 175 Answers
  • Posted on May 09, 2009
SOURCE: Treadmill slows down and stops
hi..probably the reason to this problem may be due to
worn belt and deck or a belt that needs lube.
check it out..
thank u..
kindly rate my response..
Anonymous
  • 103 Answers
  • Posted on Jan 13, 2010
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
Anonymous
  • Posted on Jul 10, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Anonymous
  • Posted on Jul 26, 2010
SOURCE: need manual for nordic track walk fit 5000 1995
I can't help with the manual. But, if you reach under the area where the readout is, push up on the cord or any of the opening underneath the display will pop out. You should be able to find the battery compartment. The unit uses 2 AA batteries. If you find a manual, let me know.
Thanks.
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Tramping noise
This seems like a lubricant issue. Most of these machine require some grease around the belts or arms. If this machine is still under warranty I would call up the company to grease it up for you. Same thing happened to me, but not this model.
Thanks
Bloomfield Computer Service
(BCS)
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_8bda69cf9239121b
Nordic track 1000 works only on speeds 1 and 7
adjust the speed sensor, see the diagram attached. clean it and test it for open or faulty. Tight the connector very well.RUN the software calibration for easy diagnose, and fix it. God bless you3_22_2013_4_23_05_pm.gif3_22_2013_4_23_19_pm.gif
I have a brand new Norditrack 1500 that makes a "knocking" noise when I start to run on it.
you can adjust the belt, see the video attached.
However try to LUBE see the video too.
Plastic under the treadmill belt is bent/warped
Dear sIR:
You must replace this parts, go to www.fitnessrepairparts.com or
www.treadmillpartszone.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Knocking, banging sound C1500 my husband just received this equipment
I would call the retail shop and they will organize a repair man out to fix from Icon Fitness. This is done under warranty .
How to fit new console to nordic track c2500
Locate the Reed Switch (10) and the Magnet (7) on
the left side of the Pulley (8). Turn the Pulley until the
Magnet is aligned with the Reed Switch. Make sure
that the gap between the Magnet and the Reed
Switch is about 3 mm (1/8 in.). If necessary, loosen
the Screw (27), move the Reed Switch slightly, and
then retighten the Screw. Reattach the Hood (not
shown), making sure the screws are in the same holes
from which they were removed. Run the treadmill for a
few minutes to check for a correct speed reading.
1helpful
How do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
6helpful
2answers
Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
