Air Tools & Compressors Logo
A
Anonymous Posted on Jan 13, 2014
Air compressor not working
Air compressor runs builds pressure an shuts off reset button does not help
5 Related Answers
John Trevino
  • 1420 Answers
  • Posted on Nov 27, 2008
SOURCE: WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Anonymous
  • 65 Answers
  • Posted on Dec 03, 2008
SOURCE: coleman compressor no build up of pressure
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Anonymous
  • 8 Answers
  • Posted on Apr 01, 2009
SOURCE: 6 gallon proforce air compressor not building any pressure
You might have a broken valve. You'll need to pull the head apart. But make sure replacement parts are available first. Does this unit have an unloader valve on it ? That could also be your problem. You probably should check this first
Anonymous
  • 226 Answers
  • Posted on May 26, 2009
SOURCE: air compressor slow to build air pressure.
you might need to checktosee if the filter is blocked or dirty were the air intake is just like a car dirt can build up there.
Anonymous
  • 226 Answers
  • Posted on May 27, 2009
SOURCE: no air pressure
TRY ADJISTING THE TANK PRESSURE KNOB WHILE RUNNING ,TURN TO THE RIGHT 1/4 TURN UNTILL YOU SEE NEEDLE MOVE .MOST TIMES FACTORY SETS AT 0,SO YOU NEED TO ADJUST IT .MY ADVICE IS NO MORE THAN 90-100 PSI TILL YOU KNOW WHAT YOUR RUNNING MORE OFTEN
Campbell Hausfeld WL65110AJ 20 gallon air compressor. Why doesn't it build pressure, then doesn't shut off?
The compressor will usually only shut off if the motor overheats or the maximum working pressure is reached.
If pressure isn't building it probably never will shut off. If pressure isn't building, either the compressor isn't pumping or air is leaking somewhere.
It is fitted with an oil lubricated cast iron twin cylinder compressor that is typically a very reliable and long-lived unit and it would be very unfortunate indeed if it gave you trouble. If it sounds normal and has strong suction through the intake the large cylinder is probably ok. This can be verified by disconnecting the receiver supply pipe from the second cylinder and estimating the pressure produced.
Rigid tristack air compressor turns on builds up pressure but reset button pop before it gets full
Amperage Overload Switch (Manual)Automatically shuts off the compressor if the temperature of the electric motor exceeds a predetermined limit
Safety valvePrevents air pressure in the air tank from rising over a
predetermined limit.
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop...
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
1helpful
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
With full tank of air, compressor turns over slow then kicks out motor reset button
Hi, my name is John. Welcome to FixYa. Check your pressure switch, it,s only supposed to build up to 135 psi and shut off, then back on when the pressure gets below 105 psi, check the oil level. thanks for choosing FixYa. ..John
My Hitachi EC12 builds pressure, shuts off, then air escapes
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However, I do want to replace it before the warm weather come to the north. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit and when using an extention cord I have a 10 guage cord that will carry the load needed to run the EC12. I have also changed to 100% synthetic oil.
1helpful
I Have a 5.5.hp oilfree air compressor that builds air up to 45 lbs an stops building pressure and keeps run.will not shut off
Is you air regulator working? I suspect your reed valves in the head need replacing as they may not be holding pressure over the 45psi that you mentioned, and are allowing the air pressure to defeat them which allows the psi over 45 psi to bleed back into the air compressor cylinder.
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
2answers
Compressor runs fast but air pressure stays low
hi your problem seems to bee that your valves are either broken or not seating properly
visit your local dealer and purchase a new valve set once fitted your machine will work fine
hope this helps ian
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Top Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
