Old post
all do, everyone. but. the devil really is in the details with EFI.
this IAC valve does that,
to speed it up warm up , put in a 195F thermostat.
this assumes 800 RPM is hot.
most of these engines, do this. new. bewlow.
1: cold start, for 3 to 15sec, 2500 rpm , worse in alaska.
2: then the above DASH pot closes and IAC takes over, at ~1200
3: then as engine heats the IAC closed inch by micro inch a
its now 100% closed and the ECU not controls idle hot.
using the modulated ISC,
there is a fast idle feature on this year, 950 to1000 rpm hot
with these turned on.
1. headlights hot.
2: defrost glass, rear.
3: heater fan on.
4: a/c on if opted.
other wise 800 is normal hot.
Engine stalling and rough run
issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
