Monitor keeps going off and on .. picture is there for split second then off then back on i can hear everything and a game program is working fine everything seems to be normal but monitor is going on and off
Check monitoc cableing. This might be the cause of cable having loose connection on the back of the monitor. (I mean data cable (VGA) not power cable)
Did you have a chance to check with another monitor? Will picture appear when cable on the back is moved?
Does this happen when you logon to bios screen? REstart PC and keep pressing F2. You will see bios screen - test unit there. If that is ok then everything is fine with the monitor.
Let me know if issue is not solved by checking cable and I will provide you futher troubleshooting steps.
Thanx
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed SAMSUNG Monitors and bad caps pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
